Old 05-19-2010, 02:01 PM   #1
Toyota1
Toyota1 is on a distinguished road
Default Need help please. 7mgte
Hey there all, i'm new to this forum great forum by the way.
Well here is my situation. I have just finished my rebuild on a 7mge. I put 7mgte pistons in chrome rings,new big end and main bearings, 7mgte injectors, also i'm runng around 9 psi boost, Now the problems are. it blows alot of soot under boost and at idle some times, uses fuel like it's going out of style. Any ideas on what to do like 7mgte ecu or ???????
Thanks heaps.
Toyota1 is offline   Reply With Quote
Old 05-19-2010, 04:00 PM   #2
FRISBEE
FRISBEE's Avatar
More info needed, what mass are you using, any mods to the fuel system ie regulator. factory turbo?? and it sounds like your using the non-turbo ecu??
1992 Honda Prelude 400Hp ??TQ
14.0@ 114MPH Time for Update
2007 Cadilliac Escalade daily
Old 05-20-2010, 12:41 PM   #3
Toyota1
Default your right
hey mate yeah it's got stocko ecu and stock fuel reg so i'am going to try a rising rate fuel pressure regulator. and another ecu. But thats all i can come up with so far what do you think?
Thank heaps mate.
Old 05-22-2010, 01:14 AM   #4
Most of the GTE electronics are NOT at all compatible with the GE's nor are they interchangeable. You can't just plug in a GTE ECU and go.
Start with adding a fuel controller and a wideband O2 sensor and gauge so you can see what's really going on with the fueling and stop guessing... you're just going to kill that engine the way you're going at it.
I do recommend switching over to the GTE electronics though, a fair amount of parts involved, but it's tuned quite a bit differently.
Old 05-22-2010, 08:33 AM   #5
Toyota1
Default yeah
I have an after market o2 sensor but not to sure if it's a wide band one how can ya tell?? Also i have a rising rate fuel pressure reg on it now what do you think of going to a biggy back ecu??
Thanks heaps for your help.
Twin turbo on 7mgte? supraman121 MKIII Supra 7 08-24-2007 02:12 PM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
7mge to 7mgte kallmijonx2 MKIII Supra 2 10-22-2006 12:55 PM
