Old 05-22-2010, 09:33 AM   #21
kadinz
kadinz is on a distinguished road
Originally Posted by fullthrottlesrqsupra View Post
just drop the oil pan and replace the rod bearings there like 35 bucks at discount auto should take about 3 hours in a driveway just buy oil a filter bearings oil pan gasket and have a good torque wrench
it should cost a total of about 100 bucks at the absolute most and you'll have an engine that you know the rod bearings are good for a long time if you do the job correctly
i was told you have to take it all out to replace the bearings??
is this not true?!?!?! i could definately do this!!
try to give me an answer by saturday mid-day, ill be lookin to buy the bearings asap so i can get this bitch runnin again!
edit:::::::: http://s398.photobucket.com/albums/p...atgirlpoop.jpg
kadinz is offline   Reply With Quote
Old 05-22-2010, 01:00 PM   #22
batmmannn
batmmannn's Avatar
Default Bearings from below
I have heard of that being done... As long as your crank is OK that should work, but if you have wear on the crank would not you have to make sure you had correct tolerances on the crank bearings?
Old 05-22-2010, 01:55 PM   #23
turbonicsperformance
turbonicsperformance is on a distinguished road
yes but if the noise hasnt been going on very long it will be fine and yes you could do this just like i said before make sure you torque the rods with a good torque wrench and make sure to lube the rod bolts and bearings when installing if you plan on doing the main bearings they are difficult in car but they are honestly more than likely perfectly fine main bearings rarely fail
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
