Old 05-21-2010, 04:54 PM   #1
BlackMK3
BlackMK3 is on a distinguished road
Default New Member, need some help.
Hey guys, my names Kevin I have a black 89 MKIII NA Supra, I recently changed my plugs and wires and now when I go start it, it idles high for about 2 seconds then just dies, I'm getting code 12, which is my distributor but it was fine before I changed my plugs. I've been reading over this forum for awhile but just never registered, I thought I'd see if you guys had any good advice for me...
Here are some pics of my car
BlackMK3 is offline   Reply With Quote
Old 05-21-2010, 11:20 PM   #2
batmmannn
batmmannn's Avatar
Default Wtf?
That makes no sense at all, changing plugs could not do this unless you made some errors in reassembling the Y assembly which has cause a fuel problem. Did you use new gaskets on your Plenum when you put it all back together? Did you mess with the throttle sensor or just leave it attached? Did you replace the plug wires one at a time so you made sure you have them on the distributer in the right places? Could they be out of order on the distributer cap? Maybe someone else could chime in
Old 05-22-2010, 12:15 AM   #3
BlackMK3
All the wires are in order, but I did make the mistake in removing the Throttle Sensor, thinking it had to come off, but I'm not quite sure what that would have to do with getting code 12?
Old 05-22-2010, 01:50 AM   #4
batmmannn
batmmannn's Avatar
Default Throttle sensor
The guys here told me to leave that alone when I was changing my plugs so I would look in the manual and see out to reset it or check that out. Hopefully you'll get better info from the others shortly.
Old 05-22-2010, 03:18 AM   #5
BlackMK3
Well, reading up on it, it seems like my problem to the T, so I'm gonna keep looking up a way to reset it, can't find a step by step for the Supra though yet...
Old 05-22-2010, 03:38 AM   #6
And that's when the TSRM ascends from the heavens, and appears as a link right on this forum.
Throttle Position Sensor Adjustment
Old 05-22-2010, 03:42 AM   #7
BlackMK3
I actually tried finding it on there, but thanks for the direct link, I'll give it a shot tomorrow...
Old 05-23-2010, 12:11 AM   #8
all hail the TSRM! ahmen
Old 05-23-2010, 02:57 AM   #9
kadinz
kadinz is on a distinguished road
check for vacuum leaks, maybe your maf is bad..
kadinz is offline   Reply With Quote
Old 05-23-2010, 12:52 PM   #10
lol yea sounds like when i accidentally did plug mine in, just runs for 3 seconds then dies.....
New member to the Internation forum AndyW Show n Tell 4 01-29-2010 08:01 PM
New member and greetings ! Qn abt exhaust yoman1979 MKIV Supra 1 12-28-2009 02:57 PM
New Member :] chroN-_^ Non-Generation Specific Questions 6 01-20-2007 10:57 PM
anybody a member of cygnus x1 site ? bennyboy55 MKIV Supra 1 10-25-2006 06:22 PM
1984 MkII front cross member needed barton MKII Supra 3 04-12-2006 04:05 PM
