Old 05-25-2010, 03:15 AM   #1
sassan
sassan's Avatar
sassan is on a distinguished road
Default 87 supra help
I just bought my first supra. its an 87 non turbo body is clean needs paint but my ? is the headlights dnt go up n down and my blinkers and emergency blinkers dnt work either. wat could be the cause of this any info would greatly help.
sassan is offline   Reply With Quote
Old 05-25-2010, 03:34 AM   #2
turbonicsperformance
turbonicsperformance is on a distinguished road
do the light turn on and off and for your hazards and blinkers check to see if your hazard switch is plugged in
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
