Old 05-25-2010, 07:33 AM   #1
supra.7mgte
supra.7mgte is on a distinguished road
Default blown turbo????
so im pretty sure i really blew the turbo up... just wanted to make sure.
well i ran it hard at about 15psi a couple of nights ago and heated it up pretty good and start loosing boost in third and fourth gear and then the next day made a second pull and spike way up to 20 psi and then the boost fell to 8 psi and stayed there and wouldnt boost higher. it was pour smoke out under WOT and even more under decel. then it will puff a little at idle and a fair bit on start up.there is quite a of shaft play in all directions. and i get a high pitched noise under boost as well.
the engine still runs and drives fine.
does this sound like its a blown turbo or anything else? and is there a sure way to tell with out pulling the turbo off the car?
thanks for the help in advance
supra.7mgte is offline   Reply With Quote
New here... need help. blown turbo? Triggarise Non-Generation Specific Questions 1 05-19-2009 05:59 PM
i may have blown my turbo? boner1115 MKIII Supra 3 11-08-2005 02:45 PM
