Old 05-26-2010, 08:55 AM   #1
Krem
Default Exhaust system & components
ok, so I'm a bit nervous. I'm building up the funds to get the parts I need... whether I'll be able to put them on myself or have to pay someone else is a fork in the road to arrive at later. Even if I have someone else do the labor, I still like to provide all the necessary parts to ensure 1) all parts are onsite and ready to go, no waiting three days for a part to arrive; and 2) ensure I'm not getting overcharged for OEM crap (possible refurb at that) that their supplier provides.
I think my headers are jacked, I'm hoping it's the cat that needs to be replaced (else I am at a loss for the cause of my present issue), and I figured if I'm doing the front half of the exhaust system, I might as well put on a pipe and muffler tip.
Anywho, here's the real questions:
1) Looking around at all these parts, I see our supra has a wide variety of part numbers on the catalytic converters... what's the difference in the parts vs different numbers? Personally, I'm looking at getting this cat as it looks similar to what I already have and matches the 2.5" that I want to achieve. Will this part be suffice? or would there be extra work in getting it to work with the mkIII?
2) I seem to see soo many different pipes for the exhaust and I'm not sure what's what. I'm looking at getting this header set. With exception of the manifold bolts, since it comes w/ a gasket, does that include all I need to go from exhaust manifold gasket back to the cat? or is there something more I need?
3) People often talk about catalytic converter repairs as nightmares. Even heard a guy say he'll toss his car if the engine, tranny or cat dies on it as the repairs become more costly than the car itself. However, looking at our car, it looks like the cat would just drop down and should make replacing quite simple? Am I wrong in my assumptions? or did we luck out with an easy to replace cat?
4) After the cat, I need to know what I need between the cat and the muffler tip. Is this considered the down pipe? exhaust pipe? and what components are involved? (I will likely have an exhaust shop make me a pipe to connect from cat to tip, if possible, I just want to know what all should be there)
5) Finally onto the tip. If I go 2.5" all the way through the system, should I stick with a 2.5" inlet? or would I be able to get away with a 2.4" inlet? That would make the difference between getting a generic tip vs a decent tip
Also any other advice or recommendations is always welcome. My biggest worry is that, short of the o2 sensor, I might miss or over look some aspect or part of the exhaust system that might cause me headaches when it comes time for the install. Thanks for makin it through my thread, and preemptive thanks for answer any of the questions above.
Old 05-26-2010, 06:21 PM   #2
Green7mgte
Supra Forum Moderator
first question... are you turbo or na?
for a turbo the exhaust set up goes like this.
exhaust header, turbo, turbo elbow, downpipe, cat, resonator, muffler. tip.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 05-26-2010, 08:32 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
The Header Set suggests it’s a N/A, good point though Green7mgte. This is the stock set up for the UK which may help, not sure if the US is the same.
Old 05-26-2010, 09:06 PM   #4
Krem
Sorry, yea, it is a N/A... getting a little power would be nice, but I really just wanna fix the issue and start drivin her again.. unfortunately, I can't really make sense of what all that stuff is. They're just part numbers in the diagram...
Old 05-27-2010, 01:51 AM   #5
Green7mgte
thats how they start out.. http://www.ma70.com/bishop92t/techtips/index.html
bottom of the page. now try to put some name on those part numbers.
that link is for a turbo tho.
setup is same buddy.. exhaust header. downpipe, cat ,resonator, muffler, tip.
Supra FAQ
Supra MKIII FAQ
Old 05-27-2010, 02:33 AM   #6
Krem
so NA only has one cat converter? right? if that's the case, it looks like I've got the majority covered... now I just need to figure out what and where to get the smaller pieces (like the 17410A or 17410B) or the bolts and things, like 90105-10023 as well as the entire set up in image 1 and 2 in the NA (looks like they're mounts?)
What was really confusing me is the second pipe that comes with the headers, I read that as being the down pipe, but I always thought the down pipe was between the cat and the muffler... I guess it's both :\
But how tough is replacing a NA's cat?
Old 05-27-2010, 12:35 PM   #7
Green7mgte
they call it a down pipe because its going "down" i speculate. technical name i guess is what? front pipe or something.
Supra FAQ
Supra MKIII FAQ
Exhaust System SideWinderGX MKIII Supra 8 02-28-2007 08:01 AM
i was thinkin side exit exhaust system for my 87 supra.... the t3d MKIII Supra 11 10-05-2006 05:02 PM
BLITZ Nur Spec Racing Series Cat-Back Exhaust System??? HeadofaHessian MKIII Supra 0 11-10-2005 05:24 AM
exhaust system kewlcoconut MKIII Supra 10 11-02-2005 07:46 PM
