Old 11-29-2006, 02:02 AM   #1
sd88supra
sd88supra is on a distinguished road
Default installing thermostat
my car is running hot again, and given that ive installed a new electric fan, new water pump, tightened my belts and got a block test (no bhg), i have yet to change the thermostat, so im guessing this is my problem. it takes a while to get hot, but even with the fan on and it being pretty cool outside the gauge goes up to red. right after hitting red and accelerating, the needle drops quickly. my guess is the coolant isnt flowing as it should due to a bad thermostat. i got a new one and will replace it tonight under artificial lighting lol. i do however have 2 questions regarding installing a new thermostat.
1. do you really have to drain the coolant prior to removing the old one? im guessing some would spill but i suppose you could just refill whatever fell out (and of course being carefull
2. i got a 180? thermostat, but whats the deal with people drilling holes in theirs? and whats the deal with a brand new thermostat not opening up when first installed? is there anything i should do to it? im guessing these leave the manufacturer ready to be installed but ill let the supra experts guide me. thanks in advance.
sd88supra is offline   Reply With Quote
Old 11-29-2006, 03:39 AM   #2
jfunez
jfunez's Avatar
no you do not have to drain the system and as long as you install the thermostat with the bleed hole on top not the bottom it'l be ok...
good luck dude...
Old 11-29-2006, 06:25 AM   #3
mrnickleye
mrnickleye's Avatar
Wink Trust Me
Just put a catch pan under the thermo area to save what spills out. For winter heater use, I use a 195* thermo.
Cut the little dangly off the thermo, and put the hole to the top, with the spring towards the firewall.
Drilling the hole to 4mm helps get the air out of the system. Our cars a NOTORIOUS for getting air in the heater core, cause its the highest spot in the system.
I change from 180* to 195* every 6 months, and by drilling that hole 4mm, I have never had the air pocket problem. You may hear the 'under dash' gurgle some, but the air will bleed out over a few days of driving.
Use a thin coating of silicone gasket sealer on the new rubber gasket, to prevent the NOTORIOUS drizzle/leakage.
After you are all done, start the motor and slowly refilled the system w/coolant, leaving the level to "just" above the core tubes. Let the engine idle for 10-20 min., keeping the level as mentioned. When you start to feel the hot water flow thru the top hose, give it a 2-3k rev on/off a couple times every minute or 2. This will help purge most of the air.
Finish topping up the radiator and install the NEW cap.
Fill the bottle 3/4 full, and check/fill it in the morning to insure you don't run out. The cold engine will suck coolant back into it over night.
Old 11-29-2006, 07:28 PM   #4
sd88supra
thanks for the info. if i dont ever use the heater, would i need the 195? thermostat at all? i live in san diego where we have nice weather and hot weather. never do i need to turn on the heater.
i do however, need my a/c from late may to early november. my a/c fan doesnt work so im gonna get a new one. however, is there anyway of wiring it so that i can turn it on with the flick of a switch without turning on the a/c? this i think would be a good idea if i was to drive in real heavy traffic when its not hot. i guess a wiring schematic for the a/c fan would help.
Old 11-29-2006, 11:34 PM   #5
j3pz
this 4mm, where does it need to be drilled?
Old 12-01-2006, 11:31 PM   #6
mrnickleye
mrnickleye's Avatar
Just open the existing hole up to 4mm.
Old 12-01-2006, 11:34 PM   #7
mrnickleye
mrnickleye's Avatar
Those a/c fan(s) operate by relays just below the battery, under the coil (N/A car). I wired in a rocker switch to the ground circuit of the relays to make those fans come on when I want.
I put the switch in one of the coin holder spots on the dash, left of the steering wheel.
Old 12-05-2006, 11:41 AM   #8
ddmcse
ddmcse's Avatar
Cool
this car does actually boilover and piss water out , or has before and it's not just a wigged out water temp gauge ?
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 06-18-2010, 02:23 AM   #9
batmmannn
batmmannn's Avatar
Default Little*dangle
Whats the little dangle you say to break off? I surely did not do that to mine. I got mine from autozone.I am having similar symptoms, though I burped the hell out of mine. Thinking of pulling it out completely now to see what that does. Mine does not boil over. If I was supposed to break something off I didn't do it, But I can drill a hole. I am considering putting my old one back in. If an NA SUpra has no fan working could that make it overheat even on an 80 degree day? Thanks
Thermostat SilenceboneSupra MKIII Supra 2 12-01-2007 06:37 AM
Which Thermostat? scruffboy Non-Generation Specific Questions 4 03-01-2007 11:18 AM
Thermostat Necessary? Bullz_EyE MKIII Supra 16 01-02-2007 12:12 AM
Checking Thermostat scruffboy Non-Generation Specific Questions 6 03-09-2006 05:49 PM
Thermostat??? kewlcoconut MKIII Supra 2 12-24-2005 08:37 PM
