Old 05-29-2010, 11:46 PM   #1
batmmannn
batmmannn's Avatar
Default Hi revs no control
Hey Guys,
I test drove my Red Supra and it did fine till I gassed it or goosed it. The revs went way up and stayed up I had to kill the ignition with the Key to slow it down. After shut down and restart it did fine till I goosed it again and then the same thing happened. I brought it home and parked it.
What does this sound like? The linkage looks to be fine. Could a Vacuum problem do this? an intake leak on the plenum I just put back on? Has anyone ever seen this happen before?
Edited later.
I did a search on this forum and found someone saying that vacuum lines swapped or a vacuum leak could cause revving.
Luckily I photographed my vacuum line positions before I took it apart. I found that I had swapped lines to the Plenum. I also did not have the metal T tube hoses all clamped. Should I re-torque the Plenum bolts? Could this have caused it?
Thanks, Scott
Old 05-30-2010, 04:08 AM   #2
907mge
907mge's Avatar
So unattended acceleration on a supra, sounds like a law suit, haha. The only thing I can think of is that your throttle body is sticking or the cables going to it. Because if you throttle body is closed the only place the engine can get air is from the idle speed control. And that t-pipe is your pcv which should not effect much if not clamped.
Old 05-30-2010, 04:27 AM   #3
batmmannn
batmmannn's Avatar
Default Hi Revs
Thats cool. thanks for answering now how do I fix it???? hehe Don't think it's the cables cause if I turn the ignition off and restart then it goes back to normal till I gas it hard again. What about the plenum gasket leaking? Maybe I need to tighten the bolts more?
Old 05-30-2010, 03:54 PM   #4
907mge
907mge's Avatar
No its probably not the bolts, I didn't put a new gasket on when I took mine off the first time. All it did was cause a poor idle because of the unmetered air. Have someone watch the throttle underhood with the car off and someone pressing the pedal to see if the plate sticks.
Old 05-30-2010, 04:51 PM   #5
batmmannn
batmmannn's Avatar
Default Hi Revving
Hmmm, Well I can try that but taking the motor to red line at a standstill is not something I like to do. So far it had only done it while driving. As far as the plate do you mean the butterfly inside the plenum or the throttle cable assembly? Thanks
Old 05-30-2010, 08:11 PM   #6
907mge
907mge's Avatar
I said with the car off and yes I am talking about the throttle plate. Its a simple way to see if it is sticking.
Old 05-30-2010, 10:10 PM   #7
batmmannn
batmmannn's Avatar
Default No Deceleration at all
Whatever it is it just got worse I have no deceleration at all now. Whatever you put the pedal at it stays at. It starts up at 3000rpm idle. Must be a problem in the plenum. Gonna have to take the air boots off and look in there. Something is very very strange here. The motor sounds great but the acceleration is a huge problem, can't be driven safely at all now. Scott
Old 05-30-2010, 11:05 PM   #8
wstanek
wstanek's Avatar
wstanek is on a distinguished road
hey had this happen once i started it just b4 buying it and it revved and stayed at 3k so turned it off and lubed the lines and all moving throttle parts its never happened again lol. knock on wood
wstanek is offline   Reply With Quote
Old 05-31-2010, 12:58 AM   #9
batmmannn
batmmannn's Avatar
Default Knock on wood!
MAN YOU CALLED THE BALL! I WAS KNOCKING ON WOOD> ACORNS!
VARMITS !!!!!!
Critters had eaten through the air filter and I had a rats next of wood and acorns and crap coming up into my throttle body! GREAT!
I wonder how much garbage I sucked into the motor. Here are some pics. Problem SOLVED! Or created from dirt in the chambers. CRAP!
Yeah I know, I should have checked this! I was just in the test driving stage.....GRRRRRRRRRR!!!! The butterfly was getting trapped by acorns!
Hopefully most of what made it into the motor was twigs, leaves and acorns shoft crap. I put my shop vac into the plenum and sucked it cleanas I could. Was running good hope it keeps going.... Damn VARMITS!
Makes me feel not so sorry for the dead critters my cats bring to the door with their heads chewed off!
ID:	3084   Click image for larger version
ID:	3085   Click image for larger version
ID:	3086   Click image for larger version
Old 05-31-2010, 01:06 AM   #10
Green7mgte
Supra Forum Moderator
lol wow.
reminds me of a time I fell out of a tree and landed on my buddys 84 mustang.. (not 5.0) I dented the hood and made his throttle cable stick from time to time.. man it was funny to see him freak out whenever he wasn't able to stop! thank god it never got anyone hurt.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Cruise control Rob1 MKIII Supra 0 05-18-2010 04:37 PM
Mirror Control doesn't work Serge MKII Supra 0 09-22-2008 12:56 AM
Weired Cruse Control Issue Chambers MKIII Supra 4 07-01-2008 02:11 PM
Lost control of my car today. redmaro Off Topic Forum 5 01-19-2007 05:04 PM
Retractor control box is the Integration Relay No.2 Burn N' Up MKIII Supra 5 04-30-2006 08:49 PM
