Old 05-31-2010, 05:42 AM   #1
dannys35
dannys35's Avatar
dannys35 is on a distinguished road
Default what are these fans for?
hey guys on my car mounted to the fan shroud there are two little white plastic fans that have two wires going to them does anybody know what they are for thanks.
1991 Supra turbo t-61 turbo 550inj high volume fuel pump cold air intake HKS blow off valve need to ge t it tuned not sure what else it has on it.
dannys35 is offline   Reply With Quote
Old 05-31-2010, 01:21 PM   #2
mirage83
A/C condensor fans.
Old 05-31-2010, 04:56 PM   #3
hmm mine turn on from time to time if its really hot out. I just thought it was part of the cooling system.
Old 06-01-2010, 02:50 AM   #4
dannys35
dannys35's Avatar
Cool thanks for the info hey have you guys looked at my other post if not will you and do you have an opinion on what the problem might be thanks.
Old 06-01-2010, 04:10 AM   #5
There are actually three A/C related fans on the GTE, one push fan mounted on the passenger side and then the 2 little (only one on pre89 MKIIIs) ones on the driver's side.
Old 06-01-2010, 12:55 PM   #6
wstanek
wstanek's Avatar
what about the 7M-GE engine same things im guessing my ac dosent work I will most likely look for issues and try a tank and dye see where its leaking then fix it iuno. W/E
Old 06-01-2010, 05:08 PM   #7
dannys35
dannys35's Avatar
Yeah I don't see a third one just the two on the drivers side maybe thats why my ac will not work.
Old 06-01-2010, 06:05 PM   #8
dumb question but just going to put it out there.. you do have a belt hooked up to your ac right?
I have a targa top. no need for ac here.
Old 06-01-2010, 10:32 PM   #9
agreed i got the sunroof so i ripped out the ac condenser/ cooler(or w/e infront of rad) and the unit on the engine w/ belt...
in all it was a good pile of weight and it cleans up the front and front engine area alot
Old 06-01-2010, 10:48 PM   #10
mirage83
The third fan (the primary one) hides in between the grill and the radiator toward the passenger side of the radiator, and is maybe 12" diameter or so.
Does your A/C come on at all? If it's low on refrigerant there's a low-pressure switch which will keep the compressor clutch from engaging.
Ign Switch Signal for Elec. Fans mkiiisupra MKIII Supra 2 03-13-2009 05:00 PM
Wiring Electric Fans mkiiisupra MKIII Supra 3 03-13-2009 04:58 PM
hydraulic fans oowee623 MKIII Supra 2 09-03-2007 05:22 AM
broken fans Supra1989 MKIII Supra 5 04-30-2006 06:50 AM
