Old 06-01-2010, 06:14 AM   #11
g.scov
g.scov is on a distinguished road
how exactly does running premium fix the problem?
g.scov is offline   Reply With Quote
Old 06-01-2010, 10:29 AM   #12
mirage83
Running higher octane (running at least 91 octane is recommended for our engines anyway) reduces the chance for detonation, but it's not a replacement for a functioning EGR system.
Old 06-01-2010, 12:49 PM   #13
wstanek
wstanek's Avatar
wstanek is on a distinguished road
I only put 91 in the tank annyways! so it dosent matter if its there for me.
wstanek is offline   Reply With Quote
Old 06-01-2010, 09:23 PM   #14
907mge
907mge's Avatar
I've talked to many people out there running without them just fine for a long time. I'm not saying its right but its not going to kill the motor by any means. You can get 93octane at the pump as well as octane booster if needed. Or just find a egr its your choice. I'd replace that heater union. They are still aval. at toyota for not that much. I got mine for arount 25 for the couple pieces.
Old 06-01-2010, 10:49 PM   #15
g.scov
ok i'll do that. any idea how much the EGR is?
Old 06-01-2010, 10:50 PM   #16
mirage83
Your choice of course, but I personally wouldn't bet my pistons on that.
Old 06-02-2010, 12:42 AM   #17
Unlike other vehicles the EGR does dick to the power band, helps with fuel economy and lowers combustion chamber temps a LOT. Running premium fuel doesn't do nearly as much as the EGR does to reduce detonation and knock. If you do run without it I recommend running a richer tune with a little less ignition advance... or a JDM ECU. It's not terribly likely it's going to kill things, but personally, I got sick of losing that kind of bet a long time ago.
A new oil pump would be BRILLIANT!
Standalone which uses the stock harness and electronics: AEM EMS
Old 06-02-2010, 03:13 AM   #18
g.scov
thanks for the info cre. that being said though, how much is an egr? or can you even buy them from toyota anymore?
Old 06-02-2010, 04:44 PM   #19
wstanek
wstanek's Avatar
Smile
i cant get 93 in stoney creek were i live cuz its canada gotta get octane booster!
Old 06-02-2010, 05:01 PM   #20
no, canada uses a different octane standard... you need to account for the different scale.
Bottom end rebuild or replace engine ? lensosupra MKIII Supra 3 05-06-2008 12:19 AM
replace engine neverbeencaught MKIII Supra 5 03-28-2008 07:57 AM
help with engine removal suprabahamut MKIII Supra 3 10-14-2007 03:32 AM
Removal of ENGINE and transmission GreenChevelleSS MKIII Supra 8 02-10-2006 06:10 PM
Parts to Replace When Replacing Engine born2drv MKIII Supra 6 10-23-2005 09:41 AM
