Old 06-02-2010, 04:17 AM   #1
Sonyps307
Default How to adjust the clutch
Hey my clutch is starting to slip is there a way to adjust it intill my new one gets here Thanks
Old 06-02-2010, 02:58 PM   #2
the short answer is no...same as the long one.
Old 06-02-2010, 03:37 PM   #3
About all you can do is make sure that you have the proper amount of clutch fluid in the reservoir, and that you have no clutch fluid leaks. Then make sure you bleed the lines
Old 06-02-2010, 04:06 PM   #4
wstanek
wstanek's Avatar
what clutch did you go with?
Old 06-03-2010, 03:21 AM   #5
turbonicsperformance
yep these cars seem to be finnicky with their bleeding i went through a full bottle of fluid before my clutch would fully engage and disengage and of course my slave is starting to go out now ... i was supposed to go to the track tomorrow
Old 06-03-2010, 03:46 AM   #6
Sonyps307
Don't know yet looking at a f1 racing clutch stage 3 or a XTD stage 3
Old 06-03-2010, 03:54 AM   #7
Sonyps307
My clutch works it is just started slipping can't take give alot of gas in 1st and 4th takes a bit to get up and moving and 5th will not go above 3000rpms
Old 06-03-2010, 09:50 AM   #8
batmmannn
batmmannn's Avatar
Default Clutch
Stop being a scaredy cat. Jack that sucker up get under it and get Greasy! I have done clutch replacement alone on my back. Was even alone wrestling the trans back in. Of course that was an MK2 so this one is probably a bitch to do. Don't forget to change the main rear seal while you are there. Putting the new plate back in is not too bad with the alignment tool they provide.
Can anyone tell me how bad it is to drop the trans? I know the starter bolts were tough are the rest of the bell housing bolts just as hard or harder to reach?
Just asking cause my clutch engaging seems kind of low to the floor right now.
Thanks, Scott
Clutch kit for a 1993 JDM Toyota Supra SpRuCe Non-Generation Specific Questions 0 04-13-2009 10:20 PM
HElp with sports clutch!! whitequasimodo MKIII Supra 3 05-07-2008 11:06 PM
