Old 06-02-2010, 05:06 PM   #11
kadinz
kadinz is on a distinguished road
Originally Posted by wstanek View Post
i mess around everyday too but cant take pictures cuz im to lazy1
yeah i got that problem too, it runs in my family... always too lazy to go that extra few feet!
kadinz is offline   Reply With Quote
Old 06-02-2010, 08:15 PM   #12
wstanek
wstanek's Avatar
wstanek is on a distinguished road
LOL Runs in the family
wstanek is offline   Reply With Quote
Old 06-03-2010, 02:00 AM   #13
Green7mgte
Supra Forum Moderator
is your oil guage stock?
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 10-27-2010, 02:55 PM   #14
gloreboy89
gloreboy89's Avatar
gloreboy89 is on a distinguished road
Default oil gauge and battery sensor now a problem on my car too
ok now my problem may not be the exact same thing as his but I have a few of his problems and i maybe related. Ok, about 2 weeks ago i changed out the spark plug wires because the old ones was worn out(IE sparks was seen at random spots on the wire). After i put the new wires in everything seemed fine until when the car hit normal operating temp. then the oil gauge slowly went down and the battery level shot up to 17ish. I dont know why it did that because not even a month ago i change the oil. The only thing I know that is wrong electricity is that the battery terminal has some white chalk like material on it that i clean every so often.
gloreboy89 is offline   Reply With Quote
Old 10-28-2010, 06:04 PM   #15
Green7mgte
whats exactly the problem? how high did your oil guage go? above 40? like way above 40 at Normal op temp?
btw the oil pressure gauge is mechanical so to speak. very good write up on how one works floating around here someplace. if i find it ill faq it.
Supra FAQ
Supra MKIII FAQ
Old 10-29-2010, 05:51 AM   #16
gloreboy89
gloreboy89's Avatar
well the problem is that the oil level is reading the wrong amount and the battery is doing the same( inaccurate readings). when i start the cold engine the oil jumps up to mid level( 40) then as the engine gets warmer(to norm op temp) the oil reading goes down to 0 and stays there until the engine is cold again.
too lazy to find a funny quote, buuuutttt off the top of my head. "life always= how well you treat your car, put crap in ur car, then car breaks down, then miss important meeting, or work which just so happen u cant miss another day or ur fired... and end up with a crappy life.
driving an '88 supra
Stock Oil Pressure Gauge 907mge MKIII Supra 4 05-14-2010 06:13 AM
Oil Pressure Gauge mkiiisupra MKIII Supra 0 01-14-2008 02:08 AM
Oil Pressure Gauge Drag0na5h MKIII Supra 5 03-22-2006 07:25 AM
oil pressure gauge problem.... SCRAMJET MKIII Supra 0 03-21-2006 06:33 AM
Oil pressure gauge Supra Guestalby MKIII Supra 0 04-23-2005 09:07 AM
