oil pressure gauge
it hasnt worked since i got the car, anyone know how to fixx this? im not sure what it is..
edit: oh, and i do not have an ohm meter >_< |
arethey electrical or standard guages im not shure!
electric..
well check your wires iits prolly wire issues. =D
thats what i thought.. meh. i guess ill check again. prolly gonna just get a new one.
i have problem now with the dome lights in the cab cuz thers no power to em now i gotta figure out where it stops! D=
nah to busy with my high school work but my caqr isnt on the road yet annyways! D=
i mess around everyday too but cant take pictures cuz im to lazy1
LOL Runs in the family
is your oil guage stock?
oil gauge and battery sensor now a problem on my car too
ok now my problem may not be the exact same thing as his but I have a few of his problems and i maybe related. Ok, about 2 weeks ago i changed out the spark plug wires because the old ones was worn out(IE sparks was seen at random spots on the wire). After i put the new wires in everything seemed fine until when the car hit normal operating temp. then the oil gauge slowly went down and the battery level shot up to 17ish. I dont know why it did that because not even a month ago i change the oil. The only thing I know that is wrong electricity is that the battery terminal has some white chalk like material on it that i clean every so often.
whats exactly the problem? how high did your oil guage go? above 40? like way above 40 at Normal op temp?
btw the oil pressure gauge is mechanical so to speak. very good write up on how one works floating around here someplace. if i find it ill faq it. |
well the problem is that the oil level is reading the wrong amount and the battery is doing the same( inaccurate readings). when i start the cold engine the oil jumps up to mid level( 40) then as the engine gets warmer(to norm op temp) the oil reading goes down to 0 and stays there until the engine is cold again.
