Old 06-02-2010, 03:51 PM   #1
seth959ci
seth959ci is on a distinguished road
Default 92 supra engine swap
im looking at ordering a new 7mge online from a jdm engine supplier, as stated my car is a 1992, will a motor from any previous year work as well?
seth959ci is offline   Reply With Quote
Old 06-02-2010, 04:00 PM   #2
kadinz
kadinz is on a distinguished road
1jz/2jz is a better choice. direct swap.
kadinz is offline   Reply With Quote
Old 06-02-2010, 04:05 PM   #3
wstanek
wstanek's Avatar
get 7m keep it 7m
Old 06-02-2010, 04:07 PM   #4
kadinz
or get a real motor...
Old 06-02-2010, 04:21 PM   #5
wstanek
wstanek's Avatar
Smile
or get the fck out of the mklll section Just kidding! =D
Old 06-02-2010, 04:25 PM   #6
seth959ci
so will any year of a 7mge work? i notice some differences on the intake manifolds... also what would be need to swap in an NA 2jz? trying to keep everything as cheap and simple as possible as a mechanic will be doing the swap. this is my daily driver so i need it done quickly otherwise i would tackle the job
Old 06-02-2010, 04:27 PM   #7
wstanek
wstanek's Avatar
go with a 7M if u need the car then u dont need to swap all the wiring harness and ECU. =D
Old 06-02-2010, 04:36 PM   #8
seth959ci
yeah.. that makes sense... so does anyone know if the later 7mge's are different than the earlier one's? the intake manifold on my car looks like it has removable plates whereas others just have the smooth y-shaped piping with no plates.
Old 06-02-2010, 04:38 PM   #9
wstanek
wstanek's Avatar
mines got plates also what year is urs and what year had the plates!
Old 06-02-2010, 04:51 PM   #10
seth959ci
mine is a 1992... im thinking it may be the 90-92(not sure) that have the plate right after the throttle body, right where the the intake manifold pipe splits into 2 pipes...
1988 supra. 350 v-8 engine swap? das_reich1984 MKIII Supra 18 04-20-2009 12:42 AM
engine swap.... hiaburi Non-Generation Specific Questions 3 05-11-2008 04:54 PM
Toyota Supra Engine Question l_o_t_s_r MKIV Supra 33 08-30-2007 02:29 AM
engine swap dom747 Non-Generation Specific Questions 12 11-17-2006 10:24 PM
engine swap loopi256 Non-Generation Specific Questions 10 09-26-2005 03:03 PM
