Old 06-02-2010, 02:58 AM   #1
turbonicsperformance
turbonicsperformance is on a distinguished road
Default n/a turbo options
whats up guys looking into doing a small custom turbo kit to run just a few psi of boost on my n/a i have basically everything just looking into electronics for it so basically has anyone else actually gone through with this besides cre? im thinking i could just run a gte afm and it would be correct enough to give my tuner decent info what do you think? im gonna run gte injectors and an apexi safc2
so basically is the gte afm the same as a ge afm just with a stiffer flap? or is it actually different i havent been able to compare the two and i dont want to spend the cash just to find out it wont work thanks guys to anyone that has some info on this
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
Old 06-02-2010, 04:16 AM   #2
The GTE electronics are VERY different than the GE in all the major places. The AFM is nothing like the GE's and isn't remotely compatible.... it'd cost some decent money for the hardware to adapt it and in that case you might as well spend the money on a better meter than the GTE's KVAFM.
Old 06-02-2010, 04:29 PM   #3
wstanek
wstanek's Avatar
wstanek is on a distinguished road
Smile
I eventually Will be doing a turbo on my 7M-GE also just after i do my rod bearings is there a decent writeup somewhere about doing this? =D
wstanek is offline   Reply With Quote
Old 06-03-2010, 02:08 AM   #4
Green7mgte
Supra Forum Moderator
this topic definitely needs to be faq.ed.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 06-03-2010, 02:29 AM   #5
Thanks for stepping up to the plate Green! I look forward to your writeup! Don't forget the pics!!!!
Old 06-03-2010, 02:48 AM   #6
Green7mgte
im on it..
hangs head.. (shoulda kept my mouth shut)
Supra FAQ
Supra MKIII FAQ
Old 06-03-2010, 03:18 AM   #7
i can document and take pics of everything as i go along but my setup will be a bit different than anyone elses as im gonna be hiding my turbo and building all my own boost pipe and with a universal fit intercooler
thanks for the info on the afm i havent had a chance to see one on the gte yet so looks like im going maftpro hate to spend the cash since im going aem when i get my gte or 2j but still its gonna need to be done im tired of only having 2 speeds while drifting
Turbo Options notmyrealname MKIII Supra 0 03-08-2010 05:52 PM
