#1 |
so basically i took my car to the car shop i go to, and had them test the coolant for hydrocarbons. came back positive.....kinda. they smelled the gasoline but the tester didnt really register. so basically since i dont know if the HG's been replaced, i'm going to just go ahead and replace it. so my first question is kinda a list of all the parts i'm going to need and if i should go with the 1.2mm or 2mm. and studs, heads ect. second question is since i'll have the car apart and stuff, what engine mods i should put on. anything will be helpfull. i think. lol thanks
#2 |
![]() Toyota Racing Development Join Date: Apr 2007
You should get the oil tested by an oil analysis lab for fuel contamination and do a leak down test to see if new rings are merited.... Now's the time to do a rebuild if the engine needs it.
NEVER run a 1.2mm HG unless you are positive you want a sizeable increase in compression ratio... especially on a turbo equipped car and especially since you're going to have to have material shaved off the head and most likely the block deck to get everything smooth enough for a metal HG. The stock HG is 1.37mmm when compressed. Look at other manufacturers for more options in thickness. If you're completely sold on HKG Stopper HGs then remember that the head and block decks MUST be smoother than glass!!!
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#3 |
Just noticed this is posted in the completely wrong section... if you're unsure of the purpose of a forum please read it (at the top of any given forum's main window) before creating a thread.
Thread moved.
#4 | |||
![]() Quote:
and same question to cre btw |
#5 |
whatever you do get arp studs if you dont already have them. they are life savers on this car.
87 Supra Turbo. JDM 7M-GTE. CT-26 set @ 10-12 pounds. xs sport manual boost control. hks ssq bov. greddy front mount. 3"downpipe with 3" straight through piping back to tip kyb shocks. ![]() "In life its not what you know, its who you know" |
#6 | |
![]() Quote:
is there a difference between the studs and bolts? i think. it seems like people talk about them as two different things |
#7 |
haha yeah i figured i got the part haha its not hard to pick up haha but just get studs i got mine from driftmotion.com its the cheapest i could find them.
#8 |
ok. sounds good.
is there any easy way to tell if i have the studs, or even if my HG has been replaced? cuz when i bought the car, i looked in the engine bay and it has the ARP sticker..... |
#9 |
The HG is only obvious if the engine is pristine and spotless and you know well what a MHG looks like in profile... if it was replaced with a composite HG, there's no way to tell that's practical.
The OEM headbolts are hex head (allen) bolts, they require an allen key to remove them. ARP fasteners are all 12 point nuts. Some off brand aftermarket fasteners I've seen were six point bolts.... Oh, and then there's the TINY print which says ARP, IIRC.
Thread Tools | |
Display Modes | |
