Old 06-04-2010, 01:52 AM   #1
booboor1
booboor1 is on a distinguished road
Default supra dying!
Hi! i have a 1987 supra turbo. I am trying to figure out what could be wrong with the car. the car idels fine, but will not rev over 2700-2800 RPM's. once it its that rpm, it feels like the car is on the rev limiter.
i am after replacing the CPS, fuel pressure regulaton, spark plugs, fuel filter, and i done a fuel pressure test and it came out fine!
can anyone tell me what to look for?? it seems to me like its a spark issue!
could it be a break in a wire somewhere or a bad coil???
it started acting like this right after i got the car back from getting a transmission and clutch installed! the mechanic told me the car was low on gas so he couldnt take it for a run but that wasnt the case!!!
thanks for your help in advance!!
josh
booboor1 is offline   Reply With Quote
Old 06-04-2010, 02:01 AM   #2
Start with checking for diagnostic error codes and then checking the mechanical and ignition timing. The details on all three are located in the MKIII FAQ section.
Old 06-04-2010, 07:54 PM   #3
booboor1
thanks for the reply, i went to read the codes but my engine light bulb must be gone. i will try to get at it the weekend and go from there!
thanks
josh
Old 06-05-2010, 02:54 AM   #4
The check engine light should ALWAYS light up when the key is in the "ON" position but the engine not running... it's a diagnostic of it's own.
My Supra keeps dying on me meteorman MKII Supra 2 07-27-2006 07:12 PM
My Supra keeps dying on me meteorman Non-Generation Specific Questions 6 07-17-2006 05:54 AM
