#1 |
Hi! i have a 1987 supra turbo. I am trying to figure out what could be wrong with the car. the car idels fine, but will not rev over 2700-2800 RPM's. once it its that rpm, it feels like the car is on the rev limiter.
i am after replacing the CPS, fuel pressure regulaton, spark plugs, fuel filter, and i done a fuel pressure test and it came out fine! can anyone tell me what to look for?? it seems to me like its a spark issue! could it be a break in a wire somewhere or a bad coil??? it started acting like this right after i got the car back from getting a transmission and clutch installed! the mechanic told me the car was low on gas so he couldnt take it for a run but that wasnt the case!!! thanks for your help in advance!! josh |
#2 |
![]() Toyota Racing Development Join Date: Apr 2007
Start with checking for diagnostic error codes and then checking the mechanical and ignition timing. The details on all three are located in the MKIII FAQ section.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#3 |
thanks for the reply, i went to read the codes but my engine light bulb must be gone. i will try to get at it the weekend and go from there!
thanks josh |
#4 |
The check engine light should ALWAYS light up when the key is in the "ON" position but the engine not running... it's a diagnostic of it's own.
Thread Tools | |
Display Modes | |
Questions about MKIV Supra | ukno0003 | MKIV Supra | 5 | 11-06-2008 10:53 AM |
Dream Offer | Karma_Supra | MKIV Supra | 22 | 10-17-2007 03:04 PM |
My Supra keeps dying on me | meteorman | MKII Supra | 2 | 07-27-2006 07:12 PM |
My Supra keeps dying on me | meteorman | Non-Generation Specific Questions | 6 | 07-17-2006 05:54 AM |
