Old 08-31-2005, 05:50 PM   #1
Intenseneal
Guest
Posts: n/a
Does anyone know of a bolt on front brake upgrade for the MKIII?? I alreadt have upgraded rotors and pads but I want more stopping power. I know Stillen make a Brembo front big brake kit but the cost is way high. I am looking for something cheap. For example: Nissan 300zx front brakes bolt up to the stock 240sx hub.
Old 09-01-2005, 03:28 AM   #2
rnoswal
rnoswal's Avatar
Take a look on ebay. Someone there is regularly selling drilled rotors for the Supra. I don't know if they are any better, but they might be.
Russ
Old 09-01-2005, 04:53 AM   #3
Troyota
Troyota is on a distinguished road
Yeah, the problem with this is that the Supra was the Top of the Line for Toyota. Most people upgrade brakes in other cars to Supra brakes. Pretty much your only option is to go with a big brake kit...our rotors are right at around 12" front and rear...I upgraded to Braided lines, slotted and x-drilled rotors...probably a good set of pads too would be all you could do outside of paying out the Azs for a big brake kit.
1987 N/A MA70 Supra <--1JZ swap in progress
1986 AE86 GT-S Hatchback
2002 DC5 RSX Type S
Troyota is offline   Reply With Quote
Old 09-02-2005, 05:54 AM   #4
Poodles
Poodles is on a distinguished road
Wilwood makes a bolt on brake kit...but it's expensive. There is a kit sold in japan to upgrade to larger brakes from other parts. The kit uses MKIV rotors, Lexus front calipers, and Skyline rears. Still pretty expensive. Don't use cross drilled rotors, they crack at the holes, and can have catastrophic failure, plus, the design is dated, modern brake compounds don't produce the gases that the cross drilling was meant to vent. Instead, get slotted rotors that remove the glazing on the pads from extreme use, and get high quality brake pads. Also, doing a full brake job wouldn't be a bad idea either...
Poodles is offline   Reply With Quote
Wilwood Big Brake kit ARZ Parts For Sale 7 09-21-2009 07:28 PM
Wilwood MKIII Rear brake kit ARZ Arizona Performance 0 03-16-2007 07:46 AM
Supra TT Brake Calipers on my MKIII tonystarks Non-Generation Specific Questions 5 05-04-2006 10:20 PM
Brake upgrade for the NA Mark III ddino77 MKIII Supra 5 07-08-2005 01:08 AM
