Old 06-05-2010, 05:16 PM   #1
brian7mgte
brian7mgte is on a distinguished road
Default non turbo head to turbo motor
im in the middle of a 7mgte motor swap the gte head i have now is garbage.. i was wondering if the 7mge head will fit the 7mgte basically if there interchangable... please let me know if u can help thanks
brian7mgte is offline   Reply With Quote
Old 06-05-2010, 05:38 PM   #2
Cylinder heads are the same, but the cams are slightly different. If you leave the N/A cams in the head and put that on your GTE, I believe that provides a little more low end power.
Old 06-06-2010, 02:57 AM   #3
The intake cam is the only difference... different on both angle and duration. Exhaust cams are same for any given year.
When swapping cams don't forget to re-shim the valves.
Old 06-06-2010, 02:57 PM   #4
joshtexican
joshtexican is on a distinguished road
So if Brian7mgte were to use the head off a 7mge,
He would'nt need to re-shim the valves would he?? (only if he were to use the cams off a 7mge on a 7mgte, correct?)
So just replace the head?
joshtexican is offline   Reply With Quote
