Old 05-18-2010, 12:07 AM   #1
batmmannn
batmmannn's Avatar
Default Codes 41 and 51
I am getting Fuel I am getting spark, My timing belt is not broken, I got codes 41 and I think 51 but not sure so I tried to repeat it and it would not flash again just stayed on. So I am baffled. My car died suddenly only fires for 2 seconds if I start it the first time every day.
41 is open or short sircuit in throttle control sensor could this be the problem. 51 is AC I am so over my head here it seems. Thanks for your help
Old 06-06-2010, 04:06 PM   #2
Let's not posts questions about our specific problems in the FAQ. Make a new post in the regular section, please. I've moved this to it's own thread in the regular MKIII section...
Code 51 is A/C switch OR IDL switch (a switch inside the TPS) You can cause this code by pressing the throttle while the engine is in diagnostic mode. Otherwise it's an indicator that the TPS needs to be adjusted (see the throttle body section under EFI in the TSRM).
AHHHH so many error codes BlueTuner MKIII Supra 2 05-04-2010 02:23 AM
Checking codes.. dunewarz MKIII Supra 2 05-08-2009 03:44 AM
Codes 25,26,51! justin1642 MKIII Supra 11 08-30-2007 08:08 PM
codes 22 24 31 kidthunder650 MKIII Supra 16 04-12-2007 11:54 PM
fault codes on a newly re-headed supra lethalwithasupra Non-Generation Specific Questions 5 09-28-2005 08:22 AM
