Old 06-07-2010, 01:02 AM   #1
LT1
LT1 is on a distinguished road
Default Toyota Supra 1989-LT1 engine ?
Can I swap a 1995 LT1 engine multiport in my car ?Here are the specs of the LT1:
5.7L Engine
Displacement 5.7L (350 cubiv inches)
No.of cylinders 8-90 degree V
Power (Acc.to SAE J1349) 260 HP @ 5000 rpm
194(kW) @ 5000 rpm
Torque(Acc
Acc.to SAE J1349) 330 (lb.ft)@3200 rpm
447(N*m) @ 3200 rpm
BORE 101.6 mm (4.00 inches)
STROKE 88 mm (3.48 inches)
Compression ratio 10.5:1
Cylinder Block CAST IRON
Cylinder Head
CAST IRON
Intake Manifold CAST ALUMINUM
Lifter Assembly Hydraulic
Intake Valve 49.3mm (1.94 inches)
Exhaust Valve 38.imm (1.50 inches)
Pistons
CAST ALUMINUM
Firing order 1-8-4-3-6-5-7-2
Left Bank 1-3-5-7
Right Bank 2-4-6-8
CRANKSHAFT CAST IRON
Main Bearings Five
Thanks for your answer---Bottom line,I want to make it fit and wants to know HOW ?
LT1 is offline   Reply With Quote
Old 06-07-2010, 01:32 AM   #2
Moved to the correct section....
Head over to SupraMania, in the MKIII Swap section you'll find info on a few various V8 swaps.
What's the value of a 1989 Toyota Supra? MysticKnight MKIII Supra 14 02-13-2011 05:26 PM
