Old 06-09-2010, 01:36 AM   #1
james089
james089's Avatar
james089 is on a distinguished road
Default Leaning out under load
the car seems to have good air/fuel when its idelling, but under load it leans out to around 16. Just installed a new aeromotive FPR, but the car still leans out. Any ideas? fuel pressure is set to 55psi. Help!
james089 is offline   Reply With Quote
Old 06-09-2010, 03:12 AM   #2
turbonicsperformance
turbonicsperformance is on a distinguished road
few questions are you turbo? if so what mods do you have done? also what wideband are you getting your numbers from some of them have a adjustment it may be off. but if you are turbo and your going to 16 on a fully functioning uego then DO NOT drive until this is fixed you'll end up causing major damage
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
Old 06-09-2010, 10:56 AM   #3
james089
james089's Avatar
7mgte engine. The mods concerning this problem are, walbro 255 fuel pump, 550cc injectors, Aeromotive FPR, Innovate wideband air/fuel meter, and i'm running a mega squirt system. I don't drive the car because i just finished rebuilding the engine. What would be a good fuel pressure to set it at? stock is 47, no?
Old 06-09-2010, 12:22 PM   #4
Green7mgte
Supra Forum Moderator
you shouldnt be leaning out with 550 injectors. whats the FPR suposto be set for those.. if you have larger injectors and a mega squirt set at stock FP. no wounder your leaning out.. sounds like you need to re-tune your mega squirter tabels
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 06-09-2010, 01:22 PM   #5
the innovative uego has a calibration procedure did you go through this procedure correctly? google it we install these all the time and when someone unhooks their battery or something they come in and complain that their car running rich/lean and we have to re-calibrate the gauge
Old 06-10-2010, 01:14 AM   #6
james089
james089's Avatar
I'm gonna try to recalibrate the wideband tomorrow morning, we'll see how that works. I'll also up the fuel pressure to just over 55psi.
Lopeing under load batmmannn MKIII Supra 14 06-10-2010 06:26 AM
vibrations under load mike_j_2me MKIII Supra 3 11-16-2007 05:21 PM
stalling under load marxdenning Non-Generation Specific Questions 1 01-18-2007 09:51 PM
