Old 06-09-2010, 03:27 PM   #1
kadinz
kadinz is on a distinguished road
Default overdrive doesn't work
the light doesn't turn on and it just doesn't work, what could be the problem?? on the highway im sittin @ 3500rpm's at 80mph.
also..can anyone tell me where the positive wire for the fuel pump is, i wanna make a fuel pump switch.
edit: since i bought the car the overdrive hasn't worked, the light has never turned on either.
kadinz is offline   Reply With Quote
Old 06-09-2010, 09:37 PM   #2
http://www.cygnusx1.net/Supra/Librar...aspx?S=AT&P=11
auto tranny troubleshooting guide. inspect your solenoid valve
Old 06-09-2010, 10:22 PM   #3
907mge
907mge's Avatar
3500 is about right for 80. If it was in third it would be alot higher rpm. Maybe the switch to turn it on/off is broken or the light in the dash is burned out. If you where going 80 in third the engine would be racing.
Old 06-14-2010, 06:04 PM   #4
kadinz
yeah but 3500 is ridiculous! i mean..the engine is already screaming at me, i just checked..these come with stock 410 or whatever big gears dont they, thats just not right.....
Old 06-14-2010, 10:25 PM   #5
907mge
907mge's Avatar
It's a 4 speed and for a car made over 20 years ago it's pretty good. Its only been recently that more gear autos have come along. My 6 speed celica runs around the same speed at 80, but it does readline at 8k though.
can you make these work with a 1jz swap..? JZA70dood Non-Generation Specific Questions 0 08-12-2009 04:17 PM
Headlights only work on High Beam - is it a fuse? t4yl0r10 Non-Generation Specific Questions 8 01-18-2008 03:56 PM
Dash lights Don't Work supra67 Non-Generation Specific Questions 4 09-05-2006 04:58 AM
Dash lights Don't Work!! supra67 MKIII Supra 0 08-10-2006 01:11 AM
