-   -   overdrive doesn't work (http://www.toyota-supra.info/forums/mkiii-supra/17101-overdrive-doesnt-work.html)
kadinz 06-09-2010 03:27 PM
the light doesn't turn on and it just doesn't work, what could be the problem?? on the highway im sittin @ 3500rpm's at 80mph.
also..can anyone tell me where the positive wire for the fuel pump is, i wanna make a fuel pump switch.
edit: since i bought the car the overdrive hasn't worked, the light has never turned on either.
Green7mgte 06-09-2010 09:37 PM
http://www.cygnusx1.net/Supra/Librar...aspx?S=AT&P=11
auto tranny troubleshooting guide. inspect your solenoid valve
907mge 06-09-2010 10:22 PM
3500 is about right for 80. If it was in third it would be alot higher rpm. Maybe the switch to turn it on/off is broken or the light in the dash is burned out. If you where going 80 in third the engine would be racing.
kadinz 06-14-2010 06:04 PM
yeah but 3500 is ridiculous! i mean..the engine is already screaming at me, i just checked..these come with stock 410 or whatever big gears dont they, thats just not right.....
907mge 06-14-2010 10:25 PM
It's a 4 speed and for a car made over 20 years ago it's pretty good. Its only been recently that more gear autos have come along. My 6 speed celica runs around the same speed at 80, but it does readline at 8k though.
