I have an 87 Supra, Turbo Targa. It's my project car and none of the lights in the cab work, dome, interior door light and door open light. Any ideas where I should look.
Already checked all the fuses. Rob87 ![]() |
i got the same problem i found out there is no power at the connector check urs and well figure this 1 out =D
I don't have power going to the lights/connectors. Not sure where to look since I'm not that familiar witht he wiring of this car.
Check your 7.5amp fuse for the domelight/hazard behind the kick panel on the drivers side first off. Once you get power there likely you will still have trouble with the dome light.I posted what I did to fix mine so run a search on dome light and you will find my post.
http://www.toyota-supra.info/forums/...ome-light.html
1987 N/A 7MGE Left Hand Drive MK3 Red 5 Speed and Black Auto Supras My Next project is the Batmobile! Last edited by batmmannn; 06-10-2010 at 04:51 AM. |
Thanks, I'll check the fuse again tomorrow morning. As for the Dome, I'll check that solder point as well. Thanks for the help.
#6 |
The dome lights is a common problem on the Supra. I had made a post a little while back, but due to unfortunate events with that Supra and a lack of a camera now, I could not add the pictures that I wanted to include with it. Typically, the problem is not the power going to the circuit; it's the ground it connects to. I'll see if I can find my old post and link it here...
EDIT: Found the thread, check it HERE. Thanks batmmannn for the last pic of the screw through the solder
1989 7MGTE R154 Targa Top White Package w/Blue Interior Driftmotion 57trim CT26, Upgraded Intercooler, 2.25" Hard Pipes, 3" Turbo Back Exhaust with Test Pipe, HKS VPC w/GM 3 bar MAP sensor, APEXi S-AFC, Walbro 255lph fuel pump, ProSport EVO Series Boost / Fuel Pressure / AFR gauges, Lotek a Pillar Gauge Pod, HKS Type 0 Turbo Timer, Eibach Lowering Springs, Tokico Illumina II TEMS struts, custom powder coated Motegi Racing TrakLite wheels Last edited by btwilson86; 06-10-2010 at 06:34 AM. |
#7 | |
![]() Quote:
#8 |
Yeah my Dome Light has gone to functional but no longer works when I open the door soooooo, I have dome lights when I push the buttons but not when I open the door and there is no fade out function any more. Man these units are finicky. It was working perfectly, but I still have dome lights so I guess I can live with that for a while.
Would you say I need to look at the door switches or again go in and solder the connections within the dome light?
1987 N/A 7MGE Left Hand Drive MK3 Red 5 Speed and Black Auto Supras My Next project is the Batmobile! |
#9 |
Love this forum. Got my lights all working, thanks to all those tips. As for the Dome ligtt, I tried the solder thing and backed away from that and found some small screws to use instead like the ealier posts stated. All lights in the cab are functioning now....
Now to my next issue.....lol Last edited by rob87; 06-18-2010 at 08:50 PM. |
Dash lights interior door lights and tail lights not working | TripleC | MKIII Supra | 10 | 03-16-2010 12:48 PM |
My brake lights are stuck on. wtf! | Isphius | MKIII Supra | 16 | 09-07-2009 08:48 PM |
NO TAIL LIGHTS!!!! quick fix | Mk3beast | Non-Generation Specific Questions | 1 | 08-24-2009 08:35 AM |
LF: Lightbulbs guide | lamw001 | MKIV Supra | 2 | 09-18-2008 02:23 PM |
Brake lights not working! | lifesnotfair | MKIII Supra | 18 | 05-05-2008 11:40 PM |
