Old 06-10-2010, 07:36 PM   #1
batmmannn
batmmannn's Avatar
Default Greasing the front end?
Hello I am wondering if there are grease fittings on the front of an 87 Supra. I can hear some creaking and my car sat for 7 or 8 years. I did a search on google and also in this forum but found no info. Thanks for your help. Scott
Old 06-11-2010, 01:08 AM   #2
No, OEM units are not serviceable. Some aftermarket suspension members have grease fitting, but don't count on it.
Old 06-11-2010, 02:46 AM   #3
batmmannn
batmmannn's Avatar
Default Bushings
Thanks Cre, I took a look and it was like a female super hero,.... no nipples to be seen.
Anyway I called the Toyota service manager and he told me that what I am hearing is probably suspension bushings.
I went to AutoZone and bought a can of silicone spray lubricant and am spraying all the bushings down.
Any other suggestions to quiet any suspension? Thanks
Old 06-11-2010, 04:19 AM   #4
Bandaid... not a fix. On the other hand when you find it you will find the source of friction which is causing the noise... Don't spray everything at once.
Old 06-11-2010, 04:33 AM   #5
batmmannn
batmmannn's Avatar
Default OOOOPs
I already did the left side. but I will take your advice and try to isolate the sound. I am getting creaking from the rear as well.
Cre, sorry but I acidentaly posted a reply in the FAQ again.... DUH. my bad...
Front and rear bumper removal CanadianBak'inSupra MKIII Supra 0 11-24-2009 03:18 PM
Supra MKIV Front Grill Durandal MKIV Supra 2 10-01-2008 02:01 AM
Two Issues: Front Brakes and Sporadic Vibration Chambers MKIII Supra 0 11-03-2007 04:15 PM
front coil spring... hangsupra MKIII Supra 6 06-03-2007 09:25 PM
