Old 06-11-2010, 01:32 AM   #1
sassan
sassan's Avatar
sassan is on a distinguished road
Default 87 speedometer problems
I have a 87 supra n/a 5 speed. my problem is that my speedometer is all wacked out. wen driving it reads about 20 mph faster than im going. so it will say im doing 85 wen only doing 65. wat would cause this problem?
sassan is offline   Reply With Quote
Old 06-11-2010, 02:50 AM   #2
batmmannn
batmmannn's Avatar
Default Speedometer Problems
I saw a post on this just last night. Larger tires could change your speedometer readings. Usually people report that the speedometer bounces or just fails alltogether.
Is your car an automatic?
Check this out:
http://www.supras.com/06/techcenter/display.php?QID=29
Old 06-11-2010, 02:58 AM   #3
907mge
907mge's Avatar
Has the rear end or the speedo been swaped out? Tires won't make that big of a difference, maybe a mile or two at most.
Old 06-12-2010, 01:14 AM   #4
sassan
sassan's Avatar
not that i know of everything is still stock and still there
Old 06-13-2010, 06:23 PM   #5
turbonicsperformance
turbonicsperformance is on a distinguished road
the springs in your speedo are shot or your speedo gear has been swapped/ your rear gearing has been search the forum for "rear gear change" there is a table that says how fast you should be going at what rpm
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
Speedometer Cable to Speedometer Sensor Swap xMCx1986x MKIII Supra 0 08-09-2009 12:54 PM
problems problems problems.... 86SupraMan MKIII Supra 5 02-04-2008 04:28 PM
Starting problems and accleration problems! alekjame22 MKIII Supra 6 03-17-2007 11:19 PM
Oil leak problems adellicson MKIII Supra 1 03-04-2007 10:11 PM
problems, problems, and problems tone loc MKIII Supra 6 09-06-2006 04:35 AM
