Old 06-14-2010, 02:50 PM   #11
bryanf89
Default I got codes
The codes i got are 24,34,14,41,43,42,51,44
im guessing thats alot of bad sensors or bad wiring
Old 06-14-2010, 04:50 PM   #12
FRISBEE
FRISBEE's Avatar
14= Ignition signal
24= intake air temp sensor
34= turbo charger pressure
41= tps signal
43= starter signal
42=Vehicle speed sensor
51= no such code
44= no such code
I would say from the codes above the accordian hose that holds your mass air sensor may be cracked or you have a boost leak somewhere.
1992 Honda Prelude 400Hp ??TQ
14.0@ 114MPH Time for Update
2007 Cadilliac Escalade daily
Old 06-14-2010, 05:31 PM   #13
bryanf89
Code 51 is signal switch error. I didnt get a code 52 or maybe didnt catch it. Should i still change my knock sensor, cre?
Old 06-15-2010, 12:08 AM   #14
FRISBEE
FRISBEE's Avatar
No I would'nt replace the knock sensor check for a vacume leak. I'm sure you pulled off some items when you installed the down pipe......did the down pipe you bought replace the o2 housing too? Clear the codes and drive the car and see if the same codes come back, some od those codes may have been old stored codes.
Old 06-15-2010, 12:20 AM   #15
bryanf89
i think i mismatched the the vacuum line routing on the wastegate...no the downpipe just added an extra 02 bung for wideband gauges
Old 06-15-2010, 03:25 AM   #16
I'm with MASSIVE boost leak + Push/pop starting a stalled car (or driving with a broken speedo cable and a bad distributor) + Stepping on the throttle while in diagnostic mode (that's your code 51, yes, it's a real code) + ..... well, something else.... <nevermind this bit.... no code 44 according to all the Toyota references I care to dig through at the moment..>.
These could all be old codes and you're just getting freaked out because you're hitting fuel cut and possibly over boosting. What's your AFR when the engine freaks and what is the boost reaching?
An O2 sensor wouldn't cause any of this, the ECU doesn't reference it at high loads.
And no, like Frisbee said, don't replace the knock sensor... see aren't you glad you stopped dicking around?
Old 06-15-2010, 03:54 AM   #17
bryanf89
i think i misinterpreted code 44, i only saw it once and i stood there for about 10mins, making sure i noted down the right codes. I don't know my AFR because i haven't installed the a/f gauge. The boost gauge is no longer working but when it was, it climbed over the 8+ mark and i was barely on the throttle, when i opened the throttle a little more, that is when i got the jerking action. Its definitely making more boost due to the bigger exhaust, i felt that from the start.
i was planning on upgrading my fuel system by a shop called e-shift performance. A guy that i know, who own an MKIV, told me that shop would get my supra up to par...as far as sensors and maintenance, what should i do? Should i get new sensors to replace the sensors that have reported error codes?
Old 06-15-2010, 05:00 AM   #18
A tip.... it's hard to listen with your fingers in your ears....
I didn't ask if it was spooling faster or boosting a couple psi more... I asked WHAT IS THE BOOST!? and IS IT OVERBOOSTING?! Also, it's been *suggested* twice that you look closely for a BOOST LEAK. Quit questioning everything and grab a f#$king wrench and actually help us help you! Also, if you don't have ANY of the equipment required to SAFELY mod the car then DON'T TOUCH IT.
Okay... so, do we now have your attention? Take your ADD meds and get with it. If you're worried about your hands getting dirty go buy some gloves. Now start pulling couplers and looking for tears, inspect electrical connectors for signs of corrosion or poor connection. Go spend some money on some basic diagnostic tools and get some actual numbers.
You didn't wash your AFM with anything did you? They're easy to murder, NEVER try to clean a KVAFM. Just figured I'd ask as you're so sensor fixated.... A shot AFM could cause most of your problems, but they don't often die horrible deaths without some help.
Old 06-15-2010, 12:13 PM   #19
bryanf89
i dont exactly know what you mean when you say "what is the boost?" its a ct-26 if that answers it and yes its overboosting for the stock setup.
im re-inspect the electrical and couplers, the only coupler i touched was that one on the turbo and that was still new as with all the other couplers that i replaced. What basic diagnostic tools should i be looking for?
No, i didnt touch the AFM.
i should also mention that the voltage test i ran on the batter stood at an averge of 13.9 on idle and 15V under engine load...when the car is running, the lights and anything electrical work just fine, but if i store my car for a bout a week, the battery would be dead.
Old 06-15-2010, 10:14 PM   #20
bryanf89
i reset the ecu and got the same codes
