Old 03-23-2011, 07:50 PM   #11
vbryanv
vbryanv is on a distinguished road
I was reading on another fourm about some using a bearing from a 92' Ford Ranger 3.0L, Napa part number HB209-KF, that you can also get from rock auto cheaper. The guy said it worked with no mod to the bearing, just had to add a steal bar acroos the bottom of the bearing due to the fact that the ford bearing insulation gets bolted to the crossmember and has nothing to hold the insuation in place.
I have not tried it yet, but i do plan on it.
vbryanv is offline   Reply With Quote
Old 03-23-2011, 10:39 PM   #12
Sonyps307
Driftmtion.com sells the center bearing for like around 200$
Driveshaft and center support bearing vibration BillW MKIII Supra 10 03-03-2010 01:51 AM
can i get some info on the center support bearing?? JZA70dood MKIII Supra 6 08-03-2009 04:01 PM
1986.5 na 5spd not starting help.. 1986.5 targo MKIII Supra 8 02-21-2008 12:56 AM
Center Support Bearing Problem purplescott MKIII Supra 0 03-27-2006 10:17 PM
Copyright ©2000 - 2024, vBulletin Solutions, Inc.
