Old 06-16-2010, 04:51 AM   #1
two-step-n
Default aem uego wide band to stock 7mgte ecu?
can i hook my aem uego wide band up to my stock 87 7mgte ecu?
Old 06-16-2010, 02:55 PM   #2
Green7mgte
Supra Forum Moderator
your wideband has a 02 sensor and another set of wires for the power..
has nothing to do with anything ecu related.. if your talking about using the voltage reading from the blue wire in the ecu (safc users know what i mean) then no.. and secondly its not all entirely accurate from what I can gather using your safc to measure afr by the voltage.
but. if your talking about using the power wires coming into the ecu to turn on your wideband.. the answer is yes, yes you can get power, but why would you tear out your glove box when you have a fuse box on the lower left hand side of your driver side kick panel.
do it right.. use the fuse box so you have a good FUSED wideband.. otherwise you could potentially cause a fire
but if your talking about "DATALOGGING" use this file
http://www.supramania.com/forums/sho...log-and-wiring...
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
How much horsepower will my stock 7MGTE tranny hold up? XxSupra-MunkyxX MKIII Supra 5 12-30-2008 06:06 PM
