Old 06-17-2010, 03:20 PM   #11
supra_rulz
supra_rulz is on a distinguished road
Originally Posted by batmmannn View Post
Does your turn like mine or is yours just solidly stuck on there and can't be moved?
.............? Shouldn't all shiftknobs be removable? especially a stick shift?
supra_rulz is offline   Reply With Quote
Old 06-17-2010, 07:24 PM   #12
wstanek
wstanek's Avatar
wstanek is on a distinguished road
they are. -.-
wstanek is offline   Reply With Quote
Old 06-17-2010, 07:31 PM   #13
supra_rulz
Originally Posted by wstanek View Post
they are. -.-
Lol. Thought so.
Old 06-17-2010, 11:36 PM   #14
wstanek
wstanek's Avatar
yeaah......tried that. Didn't work.
heat gun? is that really going to make enough of a difference that two channel locks couldn't undo?
should have used pipe wrenched they get tighter as u turn
Old 06-18-2010, 12:55 AM   #15
Green7mgte
Supra Forum Moderator
from what btwilson said. it sounds like it is fitted with a sealant from the factory. probably due to the vibrations making them come loose and what not. so they slapped some glue on it when they put it on in the factory.. a heat gun costs like 20 bucks maybe and those guys do get hot.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 06-18-2010, 01:56 AM   #16
907mge
907mge's Avatar
It could be that someone thought they would be smart and use some epoxy or glue to stop it from coming loose. Who knows what people do to a 20 plus year old car.
Old 06-18-2010, 04:54 AM   #17
907's got it here... They weren't glued on from the factory, just slightly undercut threads to ensure a high friction bond. I've seen quite a few glued on in various parts cars over the years.
Old 06-18-2010, 07:02 PM   #18
supra_rulz
greeeeaaaaat.......
ok. so i guess heatgun and melting away it is. i hope by the time i'm done i can put another shift knob back on.....
Old 06-19-2010, 12:22 AM   #19
batmmannn
batmmannn's Avatar
Default Melt away?
You're going to try and melt it off? I would saw it before I would try something like that. Cut down off center from top to bottom enough to be able to crack it with a chisel, the same way you would chisel cut a stripped nut on a rusted bolt. Use a power rotary saw to weaken it enough to break it away. This will leave it clean and ready for a new knob. Wire wheel off whatever glue they used. Even if you saw into the shifter no scarring would show once you put on the new knob. Treat it like an Apple. Just cut it apart....SIMPLE.
Old 06-19-2010, 01:06 AM   #20
Green7mgte
that post gave me a mental image of nerds on one end of the room with there gadgets trying to coerce an item off.. and in walks this big guy with a sledge hammer.. "move out the way nerds and let me SMASH it off."
gave me a snicker.
Supra FAQ
Supra MKIII FAQ
Tags
knob, removal, shift
Removing shift knob Durandal MKIII Supra 2 11-07-2010 05:35 PM
shift knob D_Train MKIII Supra 9 06-29-2007 09:16 PM
