Shift Knob
ok, so for the last month or so i've been wondering how to get my shift knob off. you guys may laugh but two mechanics and a dealership "master" mechanic later its still on there solid. apperently i have to take a hacksaw or dremmel tool and cut the top part off or just replace it with a shortshifter. either way i'm going to get destructive. is there ANYONE who might have a idea or method of getting it off? thanks
iuno try 2 pipe wrenches 1 on the shift link and one on the shift knob and giver! =D
The shift knob, as in the rubber piece? Unscrew it counter-clockwise. You may want to heat it up with a heat gun or maybe hair drier to loosen it up some
heat gun? is that really going to make enough of a difference that two channel locks couldn't undo? |
On my 2nd supra I had to use the heat gun, got it kinda gooey but it came off... My first one just unscrewed with a little TLC (it was probably removed at some point before I owned it).
In any case, you have the right idea on how to remove it- they do unscrew. |
Shift Knob
Mine turns in my hand, Figured it just unscrewed. You guys saying it doesn't unscrew?
Hmmmm
Does your turn like mine or is yours just solidly stuck on there and can't be moved?
| All times are GMT. The time now is 06:36 PM. |
