Old 06-16-2010, 09:32 PM   #1
rob87
rob87 is on a distinguished road
Default OEM head bolt torque to 74 in/lb
Would it be wise to torque down the OEM header bolts to the recommended 74 in/lb or stay with the stock torque of 54 in/lb?
rob87 is offline   Reply With Quote
Old 06-16-2010, 11:38 PM   #2
mirage83
The stock torque rating was always too low, resulted in the 7M getting a not totally undeserved reputation for bhg's. 72 is a much more reliable torque for the headbolts.
Old 06-17-2010, 02:36 AM   #3
907mge
907mge's Avatar
Inch Pounds ? Header Bolts? What?
Old 06-17-2010, 05:09 AM   #4
btwilson86
Super Moderator
btwilson86's Avatar
That's what I was thinking....
rob87- If you mean ft/lbs and head bolts, then you are right. If you are talking about torque specs on the exhaust header, then I can't help you there.
Old 06-17-2010, 10:50 PM   #5
mirage83
I figured he was talking about the headbolts from the title on the post and had just confused in/lbs with ft/lbs.
Old 06-17-2010, 11:41 PM   #6
wstanek
wstanek's Avatar
wstanek is on a distinguished road
hold on are we talking head bolts or header bolts? Because there 2 different things and the title says head bolts while u guys are saying header bolts!
wstanek is offline   Reply With Quote
Old 06-18-2010, 02:18 AM   #7
907mge
907mge's Avatar
Even so,I thought the stock head bolt torque is 58 ft/lbs not 54 and where do you get a number like 74. And there are no header bolts. There are studs though.
Old 06-18-2010, 05:05 AM   #8
Factory Head Bolt spec: 58ft lbs
(ISO Standard IIRC) 12mm x 1.25 fasteners (bolts, not studs) and ARP's required torque: 75ft lbs
(ISO spec IIRC) ARP required torque for studs: 90ft lbs
Header fasteners: 29ft lbs
Valve cover screws: 22INCH lbs
With a retorque on an old HAG there is always the danger of splitting a brittle jacket and creating a cavitation prone opening where there was none previously. I've only ever heard a couple people discuss this happening to them though and the odds are remote. You may look at it this way: If it's a stock HG... it IS going to leak eventually. The retorque simply may buy you more time. If you accept the inevitable there's really not any down side.
Old 06-18-2010, 02:09 PM   #9
wstanek
wstanek's Avatar
u knew what i meant just what is he talking about in relation to what ur talking bought
Old 06-18-2010, 04:42 PM   #10
rob87
My bad guys. It's not in/lb but ft/lb. I was just wanting to know if the oem headbolts/studs can take a retorgue of 70+ ft/lb. I'm new at the supra engine, even though I've had my car for about 10 yrs. I haven't had to do much with it after I had the engine swapt out with a less mileage one until now.
Thanks for all the tips and corrections. This forum is great!!!!
head bolt torque sequence? colbert4 MKIII Supra 2 10-04-2009 06:45 AM
Help on head bolt torque specs omar MKIII Supra 3 07-29-2009 11:35 AM
Arp Head Stud Torque Settings!?!?!?!?!? papaleach MKIII Supra 2 11-22-2006 08:20 PM
Head bolt torque kjhsupra Non-Generation Specific Questions 3 04-06-2006 09:19 AM
ARP head bolt torque Intenseneal MKIII Supra 2 08-31-2005 10:08 PM
