Old 06-17-2010, 06:44 AM   #1
batmmannn
batmmannn's Avatar
Default Cold Heater Hose and No Heat
I am wondering if no heat and cold heater hose that runs into the firewall on the passenger side could be related to any overheating issues.
I just burped my system again but this time turned the heat on high and got a couple of small bubbles out, then nothing.
I notice I have no heat and the heater hose was cool to the touch. Bad heater valve?
Any thoughts on this would be greatly appreciated, would this mean a blocked heater core? Something not working?
I found this thread but I am not sure what hose they are referring to. Is it the bottom hose that is already on the VSV that gets attached to the top of the VSV? It is not very specific. They say the bottom hose that goes to the manifold. Still not clear on this.
http://www.ddmcse.com/turbo/heatervs.htm
Thanks!
Old 06-17-2010, 11:29 PM   #2
Green7mgte
Supra Forum Moderator
you take the second vacume hose.. unhook it from the vsv and connect it to the TOP of the vsv.
least that what I made out of it.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 06-17-2010, 11:30 PM   #3
Green7mgte
is your thermostat in working order? what about your rad cap?
Supra FAQ
Supra MKIII FAQ
Old 06-18-2010, 01:26 AM   #4
batmmannn
batmmannn's Avatar
Default Rad cap and Termo
Yeah guys I already replaced the thermostat and radiator cap but got them from AutoZone. The overflow bottle doesn't smell like exhaust my oil is clear and level holding, but I am still getting an over heating.
I pushed up on the PCV a lot and ran the car trying to burp it again. Now it has good heat and my temperature control seems to be working fine.
I am wondering if my Radiator is bad or if my water pumps blades have coroded from it sitting for 7 years. It gets hot but then again I don't have a working electric fan on it yet, but still it is cool out tonight and still it ran hot.
After cool down the reservoir was full of coolant was where it was before I ran it and the radiator is now low on fluid.
Obviously I have a blockage somewhere. The car runs great other than that. Fast and powerful.
The heater works good and the temp control works now but I still have this problem.
I am thinking of getting a BHG test at my local garage and from there going toward having the radiator checked.
If those check out I have to think about a bad fan clutch though it seems to test fine when I stick a rolled up magazine against it. It has force you can't stop the blades.
I don't see a great deal of flow looking down into the radiator, not like I would expect. I wonder if the water pump is just eaten up. It doesn't leak though.
It barely blows any bubbles when I was burping it even after I opoened up the coolant to the heater core. I am puzzeled.
Any Ideas???? I don't see a leak anywhere.
Old 06-18-2010, 03:02 AM   #5
Green7mgte
that fan really does not make a difference. like i said. mine dosnt turn on all the time. I don't have a radiator shroud and I don't over heat less i have a coolant issue
Supra FAQ
Supra MKIII FAQ
Old 06-18-2010, 03:31 AM   #6
batmmannn
batmmannn's Avatar
Default No Fan
Well then I must have a bad radiator, water pump or BHG starting cause I can't figure this damn thing out.
Old 06-18-2010, 12:25 PM   #7
Green7mgte
just a shot in the dark. (but it happened to me) I tightened one of my clamps down to much and was restricting the flow.. but your saying you are getting none at all. did you do the vsv test?
Supra FAQ
Supra MKIII FAQ
Old 06-18-2010, 03:05 PM   #8
batmmannn
batmmannn's Avatar
Default Test
What is the VSV Test?
Old 06-18-2010, 07:04 PM   #9
Green7mgte
the link you posted.. did you try that?
Supra FAQ
Supra MKIII FAQ
Old 06-18-2010, 08:25 PM   #10
batmmannn
batmmannn's Avatar
Default Success
FIXED IT!
Here is the explanation I didn't want to clutter up the board any worse than I have! Thanks so MUCH!
http://www.toyota-supra.info/forums/...html#post84699
where is the heater hose??? Mark3 chinesedawn MKIII Supra 3 02-16-2010 02:22 AM
Coolent hose leak. probably heater core Green7mgte MKIII Supra 7 11-26-2009 04:43 PM
Heater hose locations suprabahamut MKIII Supra 4 12-16-2008 10:07 PM
Heater Core Outlet Hose - need help xTomKx MKIII Supra 6 11-21-2007 04:59 PM
Where is the heater core inlet hose? Brady Montz MKIII Supra 0 04-21-2005 06:11 PM
