Old 06-17-2010, 03:47 PM   #1
SupraAMS
SupraAMS is on a distinguished road
Default Diagnostic Help
So I need some help! I just bought a MKIII non turbo. Same day I drove home and on the way home the gas would stick at 4000 RPM. So first thing I did was jump on here and look for tips.
First thing I did was run a diagnostic and got the following codes:
24, 32 and 51.
I looked them up and first step was to change the air flow sensor. following that I checked and cleaned the ISC.
I then reset the ECU and ran the diagnostic again. Now I only get the 51 error.
BUT the motor continues to Idl at 3000 RPM.
Any one have a tip?
Supra AMS
SupraAMS is offline   Reply With Quote
Old 06-17-2010, 05:11 PM   #2
have you checked the fuses for everything?
just start with the cheapest thing and go up the list from there.
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=28
Old 06-17-2010, 05:43 PM   #3
Check to see if your TPS is adjusted properly. This only takes a couple of minutes with some basic tools, the steps to do it are here.
Old 06-17-2010, 05:56 PM   #4
SupraAMS
Default Help
All right going to check fuses asap.
I noticed just a couple of minutes ago that there is a lot of play in the throttle rod. It moves in a sideways motion of +/- 1cm. Which means that the throttle linkage is not totally sealed. There is a rubber seal that seems to be worn out.
Any other tips are much need!
Thanks people!
Supra AMS
Old 06-17-2010, 07:34 PM   #5
FRISBEE
FRISBEE's Avatar
I had a injector seal go bad one time and it caused a high idle once, spray some brake parts cleaner near the injectors (best stuff to find leaks BTW) and see for idle change, ya never know.
1992 Honda Prelude 400Hp ??TQ
14.0@ 114MPH Time for Update
2007 Cadilliac Escalade daily
Tags
diagnostic
Just Got A MK3 Codelicious MKIII Supra 20 02-12-2010 01:40 AM
Did a diagnostic. redmaro MKIII Supra 5 02-04-2007 04:43 AM
diagnostic scanner sd88supra MKIII Supra 1 12-08-2006 03:38 AM
so I got a diagnostic... sd88supra MKIII Supra 4 04-13-2006 12:39 AM
1995 Supra EGR Diagnostic??? johnlijo Non-Generation Specific Questions 1 02-26-2006 10:18 PM
