Old 06-17-2010, 08:05 PM   #1
AlexSchuSupra
AlexSchuSupra's Avatar
AlexSchuSupra is on a distinguished road
Default HAC Sensor?????
Looking through my Supra today and I found an HAC sensor laying around in there. I have a 1JZ-GTE swapped in my 87 mk3. I have no idea what this HAC does, beside altitude pressure or something. Can you guys tell me if the Supra still uses this HAC sensor after a 1JZ swap? If so can you tell me where it is located or supposed to be so I can see if I have one installed?
Thanks!
87' 7M-GE Custom fab 3" Headers, Cat-Delete, 4" High Flow Flowmaster (WTF!!!!) MAF Adapter with truck sized Spectre filter. NGK Laser Platinum Plugs. K&N Oil Filter
87' 1JZ-GTE Truck sized Spectre Air filter, Walbro 255LPH Fuel Pump, GM Fuel Pressure Regulator, Welded Rear end gears, Targa Top, 3" Intercooler kit, aluminium intercooler, Ebay boost controller, Ebay Oil-Catch can, I HAVE POWER STEERING AND A/C :P K&N 2JZ Oil filter, Catrol Syntec 10w-40 Fully synthetic oil
AlexSchuSupra is offline   Reply With Quote
Speed Sensor Problem (Auto) GettaRobo MKIII Supra 8 04-26-2010 12:27 PM
87 Turbo knock sensor issue supraman7 MKIII Supra 5 03-05-2010 07:44 PM
A340E Speed Sensor GettaRobo MKIII Supra 0 08-06-2009 06:59 PM
TPS Sensor and Auto Trans btwilson86 MKIII Supra 5 02-12-2008 07:31 PM
Knock sensor for an N/A. rnoswal MKIII Supra 2 11-16-2005 05:12 PM
