#1 |
are your gauges electric or analog? if they are analog you will
boost- run a vac line into your car attach to gauge and manifold vac make sure to secure lines oil psi- run the vinyl hard line to your gauge from a t fitting where your stock oil psi sender is temp- attach sensor to thermostat housing (thats where i put mine) and install the gauge the best place ive found for wires going into the car is where the speedo cable enters the car directly behind the engine all gauges probably have to run to power and ground the 3 of them should be able to run off of the ign fuse or cig lighter fuse if your gauges are electric it will be the same except instead of running hard lines you will run wires if they have a 5v reference it is for data logging and if your not tuning or logging you dont need them
92 miata 7mgte swap ![]() |
#2 |
Thanks for the info fullthrottle
I will definitely make use of this info. I dont have the gauges yet but I will prob get analog gauges. |
gauges!!! need some input | dieseltech24179 | Exterior , Interior, and Detailing | 1 | 10-13-2010 03:42 AM |
TRD Gauges Help needed | ladyangel | MKIV Supra | 1 | 06-24-2008 11:12 PM |
new gauges | Supra2NR | MKIII Supra | 6 | 09-19-2007 06:06 AM |
Aftermarket Gauges | Boombastic | MKIII Supra | 0 | 08-25-2007 10:52 PM |
