Old 06-18-2010, 05:37 AM   #1
batmmannn
batmmannn's Avatar
Default Coolant flow NOT THERE
Hey guys I need some help here, if you start your car cold and take of the rad cap off and look into the filler neck you can see the coolant flowing right? I mean you can see it flowing no problem right? Mine? No flow or minimal.
Water pump does not leak, no leaks can be found but I am overheating. Your best guess, do you think it would be a bad water pump with eaten up fins? Or do you think the radiator is blocked? Any other choices?
Car sat 7 years. Best guess?????
Old 06-18-2010, 06:30 AM   #2
no flow when the thermostat's closed.
Old 06-18-2010, 12:18 PM   #3
bat.. you really got to post under the same thread.. so new comers to your problem can look as see whats already been suggested or tried. plus it makes it a lot ezier for us to fallow what your up to when its all in the same place. so please, post the same topic under your original thread.
Coolant plugs? scaggsj MKIII Supra 14 04-13-2010 12:00 AM
Coolant on top of spark plugs suprajim MKIII Supra 3 03-24-2010 03:49 AM
Funky engine coolant issue shirkinator Non-Generation Specific Questions 1 06-22-2009 08:37 AM
