Old 06-18-2010, 02:09 PM   #1
joshtexican
joshtexican is on a distinguished road
Default Canister???
Can anyone tell me what the canister thats-bolted to the block, under the intake manifold, and right over the right motor mount is?? It is a goldish looking can that is bolted sideways.
Do both n/a and turbo motors have them?
Thanks
joshtexican is offline   Reply With Quote
Old 06-18-2010, 02:23 PM   #2
FRISBEE
FRISBEE's Avatar
I think your talking about the hard line for the fuel line it links the line from the body to the motor. If that is the one your talking about.
1992 Honda Prelude 400Hp ??TQ
14.0@ 114MPH Time for Update
2007 Cadilliac Escalade daily
Old 06-18-2010, 02:26 PM   #3
joshtexican
I would have to post a pic later, but, it almost looks like the power steering res but it bolts sideways and its right in between the lower intake mani part and the motor mount. It has a couple of vac lines to it I believe.
Old 06-18-2010, 11:53 PM   #4
907mge
907mge's Avatar
Vaccuum canister to operate the butterfly in the main section of the intake.
Old 06-19-2010, 01:52 AM   #5
I concur, the vac canister for the ACIS system is most likely what he's referring to... and no, GTE's do not have the ACIS nor the canister.
Old 06-19-2010, 02:38 AM   #6
joshtexican
Ok cool deal guys. I couldnt figure out why there was one one the nas I took out of the car.
I saw that the na motor had 3 knock sensors on it with only one connected. I started to figure it might have been a turbo block converted to an na.
The sensor holes are not tapped in they did belong there and it looks just like my turbo block. Therefore I did not know if both na and turbos had them or not.
Thanks a lot for the info
Old 06-19-2010, 04:00 AM   #7
joshtexican
by the way
What goes in place of that canister on a 7mgte??
Old 06-19-2010, 06:39 AM   #8
Originally Posted by joshtexican View Post
by the way
Nothing. The GTE and the Cressida's GE weren't lucky enough to get that system. It provides a second torque/power scale by modulating the intake acoustics (basically it's a trick of physics that allows the effect of multiple length runners without all the extra components and valving). It switches between modes (per Toyota's literature) at about 4000RPM thus providing you with more power and torque in the lower RPM than the engine would otherwise see (such as in the Cressida)... it's not so much an issue with the GTE as it begins building boost around 2K RPM (yes, the manifold pressure coming up to ambient pressure IS still boost)... so people forgive the sluggishness below that... besides... who ever drives with the RPM below that when they're trying to move fast??
The GTE and GE are the same block. The GTE just undergoes more machining after casting. Both have the three bosses for knock sensors (but GTEs will only have two drilled and tapped and GE will only have the middle one drilled and tapped), both have the bosses for the turbo oil feed and drain, but again, not drilled and tapped on the GE and so on.
Charcoal Canister, is it OK? Busted Knuckles MKIII Supra 1 11-10-2008 08:47 AM
Charcoal canister clogged elliotl MKIII Supra 0 08-27-2007 04:21 AM
charcoal canister zuni MKIII Supra 4 06-17-2007 02:03 AM
Charcoal canister removal Kuban MKIII Supra 10 05-18-2007 09:51 AM
