Old 06-18-2010, 04:46 PM   #1
rob87
rob87 is on a distinguished road
Default Coolant light on.
hello guys,
I have another question: My coolant light started coming on the other day. I checked the coolant levels and it's all good. Could it be some senser going bad? I'm not over heating either. I tried to find where this senser is and had no lock locating it, besides the temp senser. Any suggestions would be great.
Like always, you guys have helped out a lot with all your experiences.
rob87 is offline   Reply With Quote
Old 06-18-2010, 05:34 PM   #2
Double check the coolant level in the overflow reservoir. The coolant level sensor is in the bottom of that reservoir.
Old 06-18-2010, 06:18 PM   #3
rob87
Thanks, I'll check that.
Old 06-18-2010, 08:40 PM   #4
rob87
Well, pulled out the reserve/overflow bottle and noticed some gunky fluids on the bottom after I dumped the coolant. I just washed it out and now the float on the bottom is now free from gunk. Everything seems to work now.
thanks guys for the tips.
Old 06-18-2010, 09:27 PM   #5
whoot.. glad that worked for you.
those sensors do sometimes crack and break or get stuck.. a good hardy smack on the overflow sometimes works too.
Old 06-18-2010, 11:28 PM   #6
batmmannn
batmmannn's Avatar
Default Do the Flush
That gunk in the bottom of your bottle is a clear indication that your system needs to be flushed. Probably a good idea to do that before it gets problematic. There must be sludge and rust build up in your cooling system you need to get that crap out. What you found in your bottle came out of your motor.
Low Coolant Light Jay633 MKIII Supra 1 04-03-2010 10:41 PM
Low Coolant light yet again. supramacist MKIII Supra 19 04-23-2008 10:30 PM
Low coolant light wyosupra MKIII Supra 6 07-26-2007 07:27 PM
Low engine coolant light on??? 88Tsupra MKIII Supra 41 06-24-2007 03:05 AM
