Old 06-26-2010, 12:35 AM   #1
Lyndall
Lyndall is on a distinguished road
Default engine swap
Hi all,
I had a look and can't see this asked anywhere so here i go..
My dad has a 87 supra with a 7MGE in it, I would like to know if he can put a 5MGE in it out of a cressida? And if not are the heads interchangable?
Thanks!
Lyndall is offline   Reply With Quote
Old 07-21-2010, 03:44 AM   #2
I have NO idea how this ended up in the FAQ section without going to the moderation queue... I've moved it to the right section.
The 5M will *fit* in the MKIII just fine, although, I can't think of any good reason to swap it over. You'll have to make some changes (it's not a direct swap) to accommodate the 5M or you could hybridize it as you suggest... for information on that look in the MKII Supra section and at the website www.supracelica.com.
Old 07-23-2010, 03:34 AM   #3
obvious but i will point it out that the 5mge is a downgrade, and it required another electrical harness.
its really not that expensive to find and buy a 7mge and put it right back in, well not as cheap as putting a 5mge, but then you would need the wiring.
custom=money
1JZ Engine Swap into '89 Supra kyosukerob MKIII Supra 2 10-20-2009 07:49 AM
engine swap ! NYTRYDR MKIII Supra 13 08-11-2007 05:37 AM
JDM swap, now engine light, please help christutecky MKIII Supra 0 08-10-2007 07:49 PM
7MGE to 1JZGTE engine swap help please! seek102287 Non-Generation Specific Questions 2 07-02-2007 12:57 AM
Need advise on engine swap. 3RD STRIKE MKII Supra 1 06-29-2007 06:49 PM
