Old 06-27-2010, 12:27 AM   #1
thehondakiller
thehondakiller is on a distinguished road
Default Another question about manual boost controller
So I've checked about every other thread I can find about manual boost controllers and I have to get mine working correctly. I was wondering if anyone could get me a picture of where theirs is hooked in. I would greatly appreciate it. I've tried splicing it in multiple vacuum lines attempting to locate the line running to the wastegate but it still does not work. Thanks in advance.
1987 Supra "TheHondaKiller"
K&N FIPK Intake, Greddy Turndown, Cat-delete test pipe, Unorthodox crank pulley, HKS SSQ Blow Off Valve, Goodridge Steel Braided Brake Lines, Powerslot Slotted Rotors, Front and Rear Strut Bars
thehondakiller is offline   Reply With Quote
Old 06-27-2010, 04:21 AM   #2
Ball & spring type, bleed type, or hybrid?
Ball is one of the more common merely due to it's simplicity. Here's a good writeup about it functionality and construction: http://www.gusmahon.org/html/boostcontrol.htm
Old 06-27-2010, 05:22 PM   #3
thehondakiller
It's the DNA Manual Boost Controller which I believe is a bleeder valve. I was hoping to get it installed this weekend, but I have yet to get it working correctly.
Old 06-27-2010, 10:30 PM   #4
Have a couple pics? I'm sure we can get it figured out real quick
Old 06-27-2010, 10:40 PM   #5
http://www.titanmotorsports.com/dnamanboosco.html
Yeah, that's a bleed type. The more you loosen the screw the higher the boost. Generally, bleed types use a small ball valve to prevent vacuum leakage when the engine isn't boosting. look inside each nipple and see which one has the ball. The one WITHOUT the ball is what you run to the wastegate actuator, the other runs to the turbo's reference port. Simple enough.
Old 06-28-2010, 02:34 AM   #6
thehondakiller
Yah I get the routing, I was just wondering where people had placed theirs to make them more easily accesible. The vacuum line for the actuator runs underneath the turbo and then I can't find where it shows back up. I could install it underneath the turbo, but I figured it would a.) get too hot and b) be too hard to access when I'm trying to tune the boost. So I was mainly wondering if anyone had a picture of where they had placed theirs to make it easier to reach.
BTW it is the exact controller that you posted the picture of just in red.
Thank you
Old 06-28-2010, 09:13 PM   #7
couldnt you mount it in the cabin.. granted you had enough vacume lining..
Old 06-29-2010, 12:53 AM   #8
thehondakiller
Yah I could, I was hoping to mount it in the engine bay without having to run a lot of extra vacuum tubing. And also avoiding having to get in under the turbo to access the wastegate vacuum line. But it's looking like that's what it may come down to.
manual boost controller tak2099 MKIII Supra 5 11-23-2009 11:47 PM
Manual Boost Controller and Turbo timmer question ethan12510 MKIII Supra 5 02-20-2008 10:54 PM
manual boost controller!!!!!!! justin1642 MKIII Supra 6 01-16-2007 10:01 PM
