#1 |
My car has been misfiring at random times during the last week or so. Decided to take a look today, and found a small pool of oil around spark plugs 1/2 & 5/6, pugs 3/4 were unaffected . I cleaned the area as best I could and pulled the plugs, and the were covered with motor oil (may leaked down since it was hard to clean it all). I didn't see any leaks from the valve covers (had the gaskets replaced about 2-3 years ago). I'm going to take another look tomorrow, but what do you guys think? Any help is appreciated
#2 |
That's your #3 gasket leaking in the plug galley. Easy to replace with the OEM gasket, or you can use generic washers/gaskets of a size I can't recall right this moment
#3 |
BTW, the four bolts you have to pull are 14mm allen head bolts. The gaskets I mentioned earlier (if you don't want to go with a new #3 cylinder head gasket) are oil drain plug gaskets. Take one of the bolts with you to a auto parts place and find a suitable size.
#4 |
You don't need to replace the 4 plugs. On mine I did away with the spark plug valley cover and just reinstalled the plugs with RTV and it has worked very well for me. I also cleaned up the treads well. I left the cover out so I could keep track of what is in the valleys since the coolant plugs can leak also.
#5 |
Yeah, didn't realize that I had left a couple of words out as the bolts definately don't have to be replaced. Was thinking faster than I was typing.
#6 |
Be careful putting them back in I also used RTV and it worked great I have no oil leaks. Don't strip them going back in and not too tight. By the way guys my red Supra is still going strong!
1987 N/A 7MGE Left Hand Drive MK3 Red 5 Speed and Black Auto Supras My Next project is the Batmobile! |
Thread Tools | |
Display Modes | |
Help...My spark plugs are in the oil !!! | chinesedawn | MKIII Supra | 6 | 10-03-2011 09:25 PM |
Spark Plugs and Water | cgreiner | MKIII Supra | 1 | 07-21-2009 03:49 AM |
Spark Plugs (1G-GE vs 7M-GE) | makemedie | Non-Generation Specific Questions | 5 | 10-26-2008 05:19 AM |
NGK Spark Plugs | 91 Supra | MKIII Supra | 5 | 08-07-2007 03:52 AM |
1986.5 with blown Head Gasket - Removing Spark Plugs | unkymurch | Non-Generation Specific Questions | 10 | 03-02-2007 06:48 PM |
