Old 06-27-2010, 06:46 PM   #1
supraman8188
supraman8188's Avatar
supraman8188 is on a distinguished road
Question Starting Issue
Usually in the morning my car starts after several cranks then if shut it off and restart it within several minutes it starts fine, but if I wait for like 20-30 minutes it takes several cranks..It does burn some oil..so would it be that the valve stem seals are deteriorated and is leaking oil into the combustion chamber causing the problem?? Also any tips adjusting TPS relative to distributor timing? Any help is greatly appreciated.
Supe supe!
1986.5 Supra Manual Red Mica(Maroon) w/wing: Custom sound system, 18" Tork Revos, smoked tail lights, markers, and turn signals.
Mods: Eibach lowering springs, Energy poly front upper and lower control arm bushings, custom cold air intake, solid engine mounts, Magnaflow, short shifter, Optima Red Top, other custom fabrications..and yes a bra.
supraman8188 is offline   Reply With Quote
Old 06-28-2010, 04:01 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
Perhaps your cold start injector system isn't operating correctly... Check here for troubleshooting the cold start injector.
I don't understand what you're asking here... So here is a link to setting ignition timing, and here is a link to adjusting your TPS. Hopefully your answer is in there, or if you could clarify your question I may be able to help you more thoroughly.
starting issue 88 supra automatic w/turbo help! ricerbaby MKIII Supra 2 04-15-2011 06:25 PM
Wrist pin issue -- Was: Ris pen issue KeelanWiese MKIII Supra 3 02-13-2010 07:38 PM
Engine Run-on Issue gottadiesel MKIII Supra 1 04-02-2009 07:26 AM
starting motor Dom MKIV Supra 3 04-05-2007 01:57 PM
engine noise car dies after starting tex1116 MKIII Supra 7 11-18-2005 06:47 PM
