#1 |
The car will run fine until i turn it off once i shut it off it will not start back up until it sits for a few hours or i pull start it then it will run good again till turned off if anyone has any information i would greatly appreciate it.
#2 |
Supra Forum Moderator
sounds like your starter is getting hot..
does it turn on if the engine is cold with no problems? if so, run it to normal operating temp. then turn it off and take a spray bottle of water and cool off your starter. once cooled see if it will turn on. if so get yourself a starter heat shield or wrap it and problem solved. do supra's have cylinder head temp sensor.. ? Never heard mention to them or seen it in any of the tsrm..
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : |
#3 |
yea starts cold with no problem but after it warms up it quits when shut off but motor still turns over when i try starting it again that why i dont think its starter
#4 |
i had seen a post on this just a while back i think, not 100% sure but thought i did...
#5 |
did you do the spray bottle test?
check your fuel pressure.
#6 |
ok thanks ill try that
#7 |
87 Turbo Supra rough engine problem | SupraKat | MKIII Supra | 8 | 06-26-2010 05:33 AM |
New supra, computer problem, turbo problem? | mamory | MKIII Supra | 4 | 05-21-2009 04:54 AM |
Dream Offer | Karma_Supra | MKIV Supra | 22 | 10-17-2007 03:04 PM |
*_*_*_*HavInG ProBLem WitH 87 SUprA (NO SPARK) | d_demaree | Non-Generation Specific Questions | 5 | 05-22-2006 07:29 PM |
tsp problem for na t supra | jdlee123 | MKIV Supra | 0 | 09-02-2005 06:01 PM |
