Old 06-29-2010, 07:10 PM   #1
sicknasty457
sicknasty457 is on a distinguished road
Default 88 supra problem need helpp
The car will run fine until i turn it off once i shut it off it will not start back up until it sits for a few hours or i pull start it then it will run good again till turned off if anyone has any information i would greatly appreciate it.
sicknasty457 is offline   Reply With Quote
Old 06-29-2010, 07:16 PM   #2
sounds like your starter is getting hot..
does it turn on if the engine is cold with no problems? if so, run it to normal operating temp. then turn it off and take a spray bottle of water and cool off your starter. once cooled see if it will turn on. if so get yourself a starter heat shield or wrap it and problem solved.
do supra's have cylinder head temp sensor.. ? Never heard mention to them or seen it in any of the tsrm..
Old 06-30-2010, 12:00 AM   #3
sicknasty457
yea starts cold with no problem but after it warms up it quits when shut off but motor still turns over when i try starting it again that why i dont think its starter
Old 06-30-2010, 12:28 AM   #4
wstanek
wstanek's Avatar
i had seen a post on this just a while back i think, not 100% sure but thought i did...
Old 06-30-2010, 04:58 PM   #5
did you do the spray bottle test?
check your fuel pressure.
Old 06-30-2010, 05:00 PM   #6
sicknasty457
ok thanks ill try that
Old 06-30-2010, 07:55 PM   #7
FPR on vehicle inspection
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=71
87 Turbo Supra rough engine problem SupraKat MKIII Supra 8 06-26-2010 05:33 AM
New supra, computer problem, turbo problem? mamory MKIII Supra 4 05-21-2009 04:54 AM
*_*_*_*HavInG ProBLem WitH 87 SUprA (NO SPARK) d_demaree Non-Generation Specific Questions 5 05-22-2006 07:29 PM
