Old 06-30-2010, 12:18 AM   #11
rob87
rob87 is on a distinguished road
it has a new thermostat, just put it in about three weeks ago. I put it in then because I noticed the thermostat housing bolt was missing/broken, so I replaced it since I was working on that anyways. I'll check the codes here in a little bit. I have no warning lights that indicate any issues, just that the temp gets high at constant high speed over 20 minutes or so.
rob87 is offline   Reply With Quote
Old 06-30-2010, 12:30 AM   #12
wstanek
wstanek's Avatar
wstanek is on a distinguished road
Iuno im prolly just getting tired long day at work... haha... no but seriously long day.
wstanek is offline   Reply With Quote
Old 06-30-2010, 12:38 AM   #13
rob87
just checked the error codes and I have no errors.
Old 06-30-2010, 12:40 AM   #14
rob87
And yes, it has the OEM heat shield around the turbo.
Old 06-30-2010, 04:17 AM   #15
batmmannn
batmmannn's Avatar
Default Air in your System
If it started after you changed your thermostat I would think you have air in your cooling system. Time to Burp it.
Old 06-30-2010, 12:57 PM   #16
agreed with batmmannn
its manditory that after flush, keep rad cap off and idle car until at operation temp and even keep going for another 15-20 mins.
this should remove air in the system.
think the term would be vapor lock. my buddie just did that to his truck but aparently he ruined his heater core, and still has not fixed his overheating problem.
Old 06-30-2010, 02:36 PM   #17
rob87
Sounds good guys, I'll try that today when I get home from work. I did push it this morning on the way to work and the temp gauge never moved from its normal operating temp reading....????
Old 06-30-2010, 06:20 PM   #18
batmmannn
batmmannn's Avatar
Default Burping
When you do it park it facing up a hill. This gets the heater core lower than the radiator cap. Rev is to 3K a few times while clearing out the air. Like he said about 15 to 20 minutes with the rad cap off.
If this does not fix the problem, remove your thermostat and cut the dangle and drill a 4mm hole where the dangle was. Mine didn't clkear all the air till I drilled my thermostat.
Old 06-30-2010, 06:50 PM   #19
Green7mgte
Supra Forum Moderator
yea I heard someone suggest drilling a hole in the thermo.. still dosn't sit right with me.
besides i think the waterfall sound is COOL!
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Shaking at high speeds. MarkLinRacing MKIII Supra 7 03-07-2010 08:39 AM
Brake loss at high speeds 86.5 7MGE MKIII Supra 15 10-28-2009 04:28 AM
