Old 06-29-2010, 07:43 PM   #1
rob87
rob87 is on a distinguished road
Question High speeds for 15min or longer, temp gets high
So I have a quick question, I hope.
When I do over 85mph for over 15 minutes, temp gauge starts to climb but doesn't reach red line, about two ticks away. If I just drive it under 85 mph, temp gauge stays at normal operating mark (about 1/3 on the OEM temp gauge). Coolant has been flushed and replaced, oil changed, filter changed. I'm not see any coolant leaks or losing any, as far as I can tell. I do have the flexlite electric fans instead of the OEM fan. So, I'm looking for any tips on where I should look or go to figure this out. Could it be the electric fans can't keep up with the higher speed to keep engine cool or is it somewhere else in the engine I need to check? Any help would be great here.
Rob87
rob87 is offline   Reply With Quote
Old 06-29-2010, 07:45 PM   #2
rob87
Forgot to add what I'm driving:
87 Turbo, 5 speed, not really any mods on it yet, just want it running right first. It does have an open intake and after market BOV and open/screen fiber hood.
Rob87
Old 06-29-2010, 07:59 PM   #3
thehondakiller
thehondakiller is on a distinguished road
Are you running your A/C while you're driving it and it is heating up?
1987 Supra "TheHondaKiller"
K&N FIPK Intake, Greddy Turndown, Cat-delete test pipe, Unorthodox crank pulley, HKS SSQ Blow Off Valve, Goodridge Steel Braided Brake Lines, Powerslot Slotted Rotors, Front and Rear Strut Bars
thehondakiller is offline   Reply With Quote
Old 06-29-2010, 08:01 PM   #4
rob87
I'm not running the AC, that is another problem I have to fix but that's for another day..lol
Old 06-29-2010, 10:18 PM   #5
wstanek
wstanek's Avatar
In my 87 N/A manual it shows that the regular operating temp is anywhere for 1/4 to almost red lines on stock temp gauge. so from the sounds of it doesn't look as though its over heating~
Old 06-29-2010, 11:35 PM   #6
batmmannn
batmmannn's Avatar
Default Overheating
Well that can't be right cause my temp guage never reached the red and my radiator was boiling so I don't think that estimate could possibly be correct as far near the red being normal.
Old 06-29-2010, 11:46 PM   #7
wstanek
wstanek's Avatar
well a couple b4 the red line in the ORIGINAL manual for 87 supra N/A Standard says almost b4 red is not over heating
Old 06-29-2010, 11:53 PM   #8
batmmannn
batmmannn's Avatar
Default b4 Red
Well then they must be cooking eggs, cause at that temp my car was boiling so bad it was leaving and overflowing the overflow bottle.
Old 06-29-2010, 11:58 PM   #9
wstanek
wstanek's Avatar
lol Toyota derp!
Old 06-30-2010, 12:04 AM   #10
but it will tell you that is NOT normal operational temp, if it goes over half way you have a problem somewhere...
did you replace your thermostat
does your turbo have the stock heat insulator? or heat shield of some sort?
make sure your getting enough antifreeze and you could try adding a coolant additive.
CHECK ERROR CODES!!!!!!! ALWAYS CHECK ERROR CODES!!!!!!!
learn how to check here:
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=23
(jumping of terminal te1 & e1 can be done with a pape clip)
if the ac doesnt work why keep it?? really it just slows us down and gets in the way under the hood, the system weighs a fair bit i dropped mine
Shaking at high speeds. MarkLinRacing MKIII Supra 7 03-07-2010 08:39 AM
Brake loss at high speeds 86.5 7MGE MKIII Supra 15 10-28-2009 04:28 AM
