#11 |
Yes but over 50lbs more torque. But the main thing is that a turbo has potential that a na will never even come close to.
#12 |
im talkin about my mk3. but i crushed it into a highway meridian 5 months ago ish...
pushed the front left side of the bumper to where the battery should be, battery crushed some stuff, also broke my drivers side cross member and completely ruined front sub frame... mk2s in my opinion are not meant for high speed. in my experiences every time i have ever broken 200km/h a random piece of plastics/trims flys off and i have to go find it...i just stopped going fast with my mk2
1984 supra - 1uzfe - w58 - 4.10 - 1 piece aluminum shaft. |
#13 | |
![]() Quote:
all hail the turbos
#14 |
Yeah OK Turbo is the way to go for fun and speed, but are they just as reliable? I mean the stock ones. Why all the talk about so many failures? Is it because of the mods guys do? If you had a stock Turbo would it drive as many miles reliably and cheaply as an N/A over the life of standard use?
1987 N/A 7MGE Left Hand Drive MK3 Red 5 Speed and Black Auto Supras My Next project is the Batmobile! |
#15 | |
![]() Quote:
really?? really... no car nearly 25 years old is going to be reliable... if you want that, i suggest you sell me your supra and go buy a honda accord. and really now, think back to the day in 1987 you could buy a brand new "Supra" or you could go with the Turbocharged version with more hp and torque. WHO THE HELL would not go for the turbo version!!!!! plus a stock ct26 isnt capable of pushing vary much psi. if your not mechanical savy, install an intercooler and radiator, these things extend your engine and turbo life. yes there is a hg problem. yes it can be fixed. i only purchased a non turbo because it just had a hg done and my friend gave me a deal. still fast as hell, but the turbo knocks its pants off
#16 |
I don't think you answered my question, but thanks anyway.
#17 |
Supra Forum Moderator
the ct-26 turbo is a robust little guy.. small but reliable
130k on my turbo. and just now in need of a rebuild.. still no smoking or shaft play.. just leaks some oil.. as far as the 7mgte engine is concerned.. just as reliable as any other 20 year old motor..
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : |
#18 |
The 7mgte can be very reliable. The main thing is to redo every thing the right way and replace the parts that should be replaced. I think where people go wrong is with the power. The more power you produce the more likely something is to break.
#19 |
I bought my mk3 from a lady who had bought it off the showroom floor back in 1986. It has 197000 miles on the original motor and turbo, and I have yet to have a mechanical problem with it. The lady who owned it maintained the mechanical portion of it beautifully. (I can't say the same about the interior however). She even had all of the mechanical records for the last 23 years back to it's first oil change. (Which only cost $6.95 from the dealer) So is it reliable? In my opinion yes. But it takes a lot of maintenance to keep it that way.
1987 Supra "TheHondaKiller" K&N FIPK Intake, Greddy Turndown, Cat-delete test pipe, Unorthodox crank pulley, HKS SSQ Blow Off Valve, Goodridge Steel Braided Brake Lines, Powerslot Slotted Rotors, Front and Rear Strut Bars |
#20 |
so does any other 20 year old car.
Thread Tools | |
Display Modes | |
HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 4 | 02-28-2009 07:26 AM |
Dream Offer | Karma_Supra | MKIV Supra | 22 | 10-17-2007 03:04 PM |
Sequential Turbo Question | suprapoweredsoarer | MKIV Supra | 1 | 06-06-2006 12:13 AM |
Everybody goes Turbo here - Can N/A Supras be fast? | lifesnotfair | MKIII Supra | 32 | 04-01-2006 01:25 AM |
